electronic rear suspension
Old Nov 24, 2003 | 10:01 AM
chillmcduff's Avatar
does anyone know how to change the rear struts to make them non electronic? I am trying to lower my car on st springs but stock replacements are $500 a piece. I was told that inserts (whatever they are) will work to make them non electronic. This is confusing because the search function is down and not many people know about this. If anyone has any info on what parts I need, and where to get them; I would really appreciate it. Thanks, Aaron
Old Nov 24, 2003 | 11:14 AM
internetautomar's Avatar
mod or sell?
Instructions come with the replacements,
Which I sell
Old Nov 24, 2003 | 11:42 AM
Are you sure that they will replace the electronic suspension? So it is just an insert that goes inside the old strut?
Old Nov 24, 2003 | 11:43 AM
Matt93SE's Avatar
STFU n00b!
Yes.
you pretty much just unplug the electronic stuff and swap these. problem solved.
Old Nov 24, 2003 | 11:50 AM
The rear struts that I bought from KYB were just a tube. The guy who is installing this for me said that I need the tube with the metal casing around it that holds the spring in place. Do I need to buy a seperate casing to hold the spring in place and weld it to the tube? I'm still not sure.
Old Nov 24, 2003 | 11:52 AM
mod or sell?
You need a different mechanic!
or one one who will at least be honest about the fact that he wants his markup on the parts
Old Nov 24, 2003 | 12:02 PM
I just talked to a parts manager at a local nissan dealership. He said that if I replace just the cartridges for the rear electronic struts ($120 a piece) that is all that I need to make the rear struts better. So is the cartridge the same thing as an insert?
Old Nov 24, 2003 | 12:16 PM
subs1000w's Avatar
yes the insert is the same as a cartridge but you can get the non electronic for alot less than 120 a piece adn you wont know the diference
Old Nov 24, 2003 | 01:40 PM
Matt93SE's Avatar
STFU n00b!
Here's directions on how to do it yourself. It explains everything you need to know.
http://www.4dsc.com/articles/suspens...ico/rear.shtml
See the two cartridges at the top? those are the rears. you pull the guts out of the factory struts and slide these in. the only other thing you need is the glad packing nut, which is the big gold colored nut that goes on the top of the struts. they are included when you buy new struts/cartridges/inserts/whatever.
I don't wanna be rude man, but this is very basic stuff on this car. I'm glad you're taking it to a mechanic if you can't do it yourself, but this guy doesn't sound like he's ever worked on one of these cars. it's NOT hard, but if he has to ask questions like that, I wouldn't trust him to change my oil..
Old Nov 24, 2003 | 01:42 PM
I can't use the non electronic strut cartridges that I got from KYB because they are the same size as the whole stock strut. Also it is just a tube. The stock tube is welded to the casing that holds the spring in. The replacement is the insert on the inside, which are too small for the KYB non electronic cartridge. I think that I have to get the cartridge for electronic suspension.
Old Nov 24, 2003 | 01:48 PM
The KYB's that I got look just like that, you're right. But the electronic suspension is different. It is one whole piece. The collar that sits the spring in place is welded to the cartridge. So, it doesn't make sense how to replace the cartridge with a non electronic one. Do you understand?
Old Nov 24, 2003 | 02:38 PM
Matt93SE's Avatar
STFU n00b!
Tell ya what.. just go to a junkyard and buy the non-electric rear suspension off a car that's been torn apart.. make sure you get one with the same brake setup as you, otherwise they won't match up.
then you can stick any aftermarket strut in there and it won't matter.
What's the OD of your adjustable strut shaft then, anyway?
I have a hard time believing nissan made yours smaller than alllll the others out there.
Old Nov 24, 2003 | 02:44 PM
Jeff92se's Avatar
I'm needing a caw
Be nice guys. He emailed me and I suggested he post the question because I didn't know. Thanks for the replies Matt and internetautomar
Old Nov 24, 2003 | 04:50 PM
mod or sell?
I have been nice I even talked to him on the phone.
Old Nov 24, 2003 | 05:33 PM
Don't worry, you all seem pretty cool. And thanks for all the help. Honestly, I havn't seen the OD of the shaft myself; maybe I should. And wouldn't it make more sense to just change the cartridge for the electronic suspension, than change the whole setup to non electronic? Also, what does the electronic suspension do? I'm assuming that it lowers the car at higher speeds.
Old Nov 24, 2003 | 05:45 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
we have an electrinic suspension ? WTF does that do ?
Old Nov 24, 2003 | 05:59 PM
mod or sell?
Only a very few escaped the factory with the electric suspension. Personally I've never seen one in the wild.
They're about as rare as Manual trans Caravans
Old Nov 24, 2003 | 06:44 PM
davebond007's Avatar
Except Caravans break down.
Old Nov 24, 2003 | 08:12 PM
Matt93SE's Avatar
STFU n00b!
so does the electronic suspension. And at $500 per strut to replace, it's stupid to fix it.
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
doctorpullit
Sep 10, 2015 06:33 PM
ef9
Sep 5, 2015 11:18 PM
A32goldylocks
Sep 2, 2015 06:39 AM
