fuel smell
Old Nov 25, 2003 | 07:04 AM
tmuscedere's Avatar
fuel smell
Here is one for you guys, Just recently I have started getting a really strong fuel smell from my car. All the fuel lines were replaced last year as well as the fuel injectors on the car. Since then I have not had any problems with smell. What I have noticed is around the number 1 fuel injector that its damp. could such a small leak give off that kind of smell or do I have other problems somewhere else. The gas tank look dry underneath, and the smell doesn't change full or empty.
Old Nov 25, 2003 | 07:26 AM
Matt93SE's Avatar
STFU n00b!
I'm going to make a guess and say that it's a leaking O-ring around the injector.
it doesn't take much for a fuel smell, let alone a fire.
Old Nov 25, 2003 | 08:00 AM
internetautomar's Avatar
mod or sell?
you mean he shouldn't be smoking under the hood?
Old Nov 25, 2003 | 08:06 AM
cneary812's Avatar
smoking under the hood is bad.
also check your fuel filler tube and vent hoses for cracks while you are looking. And your evaproative canister
Old Nov 25, 2003 | 09:01 AM
tmuscedere's Avatar
thanks, going to go over the entire fuel system on the car. I think that its the fuel injector seal the most though.
Old Nov 25, 2003 | 10:26 AM
94M@X's Avatar
Anyone have a pic of the fule injector seal?
Old Nov 25, 2003 | 10:32 AM
Matt93SE's Avatar
STFU n00b!
I'm sure your handy FSM does.
Old Nov 25, 2003 | 11:32 AM
tmuscedere's Avatar
Basically you have two o-rings sealing the injector a upper and a lower ring. the reason for the two rings is that the injectors are side feed type.
Old Nov 25, 2003 | 11:40 AM
subs1000w's Avatar
it could also be the rubber washer that goes between the injector and the lower intake plenum
Old Nov 25, 2003 | 11:44 AM
Jeff92se's Avatar
I'm needing a caw
Yeah here. IN THE STICKIES DAMMIT
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
msellas
Sep 23, 2015 09:16 PM
