change idle???
Old Dec 13, 2003 | 11:47 PM
maximum_mxma89's Avatar
change idle???
recently, the idle on my max has gone way down. it used to idle at about 900-1000 rpms. but now its down to about 500 and the engine seems to spudder a little. we tried adjusting the actual cable in the engine but that didnt work. after talking to a nissan mechanic, i was told the ecu controls the idle speed. so does anyone know how to adjust it, or is this something only nissan can do? (i searched the manual a million times and found nothing on how to adjust idle).
thanx
Old Dec 14, 2003 | 08:21 AM
harrymay's Avatar
is it usually idling at 900-1000 when cold, xoz my gxe idles at 750-760 when warm, and when in drive it goes o 500. i just had a problem with shuddering coz i bought some cheap gas, its fixed coz i went and got shell gas. chck injectors and spark plugs, your cap and rotor too
Old Dec 14, 2003 | 10:22 AM
drstillpatient's Avatar
thanx
cold start idle = 1500 rpm.
normal idle = 750 rpm.
the little screw on the right side of the ECU should be all the way anti-clockwise . thats the factory setting. did somebody adjust/increase the idle speed?
idle is also effected by the condition of your air filter, fuel filter, IACV and a few other things. start with the basics.
Old Dec 14, 2003 | 07:46 PM
i know when its cold it idles high, usually around 2k rpms. when warm though it shoots down to 500, and gets a bit unstable. and it never did that before. only until recently when i put the stock airbox back on! could this have messed somethin up? i always use premium gas and the injectors are clean so i know its not one of those. input is appreciated. thanks! =)
Old Dec 14, 2003 | 08:28 PM
MrGone's Avatar
take off the passanger side ECU cover thing
that little screw adjusts the idle. Spipedong was messing with this on his car.
Old Dec 15, 2003 | 03:08 PM
harrymay's Avatar
i took off my stock airbox and then replaced it, the car started to idle funky, i thought it was either the maf or the gas since id just filled up, turns out it was the gas, i filled up with shell, and the problem is gone.
id say try the deally on the ecu, just be careful. it may be the maf if that doesnt work
foodmanry
Sep 24, 2015 12:02 PM
97_GXE
20
Sep 17, 2015 08:12 PM
lrb6805
Sep 17, 2015 04:49 PM
