How to Adjust the Handbrake
I'll start by saying I've tried searching on 2 different computers and 2 different browsers. No luck. (I used to be ale to search, don't know what happened)
I'm wondering if anyone knows how to adjust the hand brake on a 3rd gen max. It's a five speed if it makes any difference. Right now it's so loose it barely holds me on a hill when pulled all the way. I've heard you can usually just pull off the center console and adjust a bolt to tighten it. Well, I've got the center console laying on my driver side seat and I don't see any bolts.
I also noticed a couple of electrical connectors/cables which run up to my shifter, but don't connect to anything. WTF is that all about?
THANKS!
THANKS!
THANKS!
THANKS!
My brake was loose like that... it wasnt because I needed to tighten the bolt in the console but because the thing the cable pulled on on the caliper was frozen in place(drivers side) I haven't pulled the wheel off the pasengers side but i assume that one is frozen too... so if tightening the bolt doesnt work for you take the back wheels off and check to see if anythign is frozen...
I really must be missing something. There are 2 12mm bolts holding the handbrakes' frame, but nothing to adjust. I shot some cleaner into the brakes. that's all I have time to do rigght now. I guess I'll have to try again later.
tarun900
19
12-20-2021 06:57 PM
04-16-2020 05:15 AM
