windshield wipers stopped working
Old Dec 14, 2003 | 08:05 PM
ArcticDC5's Avatar
So I took my newly purchased 91 SE with 141k miles to NC from NJ and back this weekend. The round trip was 1,300 miles. The day I headed back, it was raining all day so I had the wipers on the whole time literally, but not continious. So my last 20 miles to my house, the wipers just stick in the up position and can't figure out why they just stopped after I hear the motor still going in its intervals. I pull over and push em down and pull em up with the motor going and they just flap in the wind basically. Can anyone help me tell me how to fix this problem or what went wrong?
Old Dec 14, 2003 | 08:52 PM
internetautomar's Avatar
mod or sell?
uhoh sounds like a bad linkage or if you're lucky you just lost a nut.
Old Dec 14, 2003 | 09:02 PM
phat's Avatar
sound like the spline between the base of the wiper and the rod of the wiper are worn. Unscrew the nut and check the connection. If the teeth on the wiper is worn, pick up another one in the junk yard. You can get all of them from the junk yard.
Old Dec 14, 2003 | 11:07 PM
Bman's Avatar
If the wipers still move together but motor doesn't move them, it sounds like the connection near the wiper motor has popped off. You'll have to unscrew the cowl cover to see anything. Popping it back on or replacing one of the levers in this area should fix it, as the thing uses plastic bushings. Just popping it back on may leave possibility of future breakdown though.
It sounds like both wipers stopped working so if this is the case it shouldn't be loose nuts or bad splines as they wouldn't both go bad together.
Old Dec 15, 2003 | 01:11 PM
StRacer718's Avatar
My mom had this problem with her old 88 Jetta a the screws on her wiper arms were stripped. We just had to replace the arms with new ones.
Old Dec 15, 2003 | 03:20 PM
hotmax97's Avatar
I HAD THE SAME PROBLEM AND I WAS THE RUBBER THAT HOLDS THE ARM
TO THE WIPER MOTOR IT POP OUT AND IS VERY HARD TO GET IN THEARE
jerrod99_se-l
Aug 27, 2015 08:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
MidnightMaxima_22
Aug 19, 2015 01:01 PM
jchronis2552
Aug 13, 2015 07:48 AM
kenc15
Aug 5, 2015 08:29 AM
