Oil in Intake manifold and Plenum
Old Dec 27, 2003 | 08:20 AM
MP3Car's Avatar
I am changing my knock sensor, and rear valve cover gasket, and I noticed a lot of oil build up, wet oil, on the intake manifold, and the lower part of the plenum...
I'm thinking my valve seals are leaking... causing what little amounts of oil are in the chambers (asuming my rings leak a little, they dont leak that bad bc I'm not pouring out smoke) to be blown into the intake manifold during compression.... I have not done a leak-down test yet....
Anyone have any ideas??
Old Dec 27, 2003 | 08:50 AM
Matt93SE's Avatar
STFU n00b!
there can also be a lot of blow-by from the PCV valve and also through the other valve cover vents. it's pretty common. not much to worry about.
A lot of the nasty stuff you see on the manifolds is varnish that's built up over time though. clean it off and it'll still be clean in another 30k miles.
Old Dec 27, 2003 | 09:50 AM
MP3Car's Avatar
Look at the difference in build up between the different banks.... think the front bank is running rich?
http://members.***.net/mp3car/1.JPG
look at all the oil/carbon build up, especially look how after tha plenum has sat in this position for an hour or so, the oil has run down from the walls of this duct and pooled
http://members.***.net/mp3car/2.JPG
Here notice the "rear" 3 ports, which go to the front bank, havea lot more build up as well...
http://members.***.net/mp3car/3.JPG
Think all this looks acceptable? 92SE 108k miles.
Old Dec 27, 2003 | 12:04 PM
MrGone's Avatar
you should see how dirty my 165k mile engine was.
i think your in good shape.
(just clean it )
(oh yeah, your valvetrain looks clean as well. Nice clean semi low mile engine
Old Dec 27, 2003 | 02:35 PM
Matt93SE's Avatar
STFU n00b!
That's not too bad. yeah, the oil isn't something you like to see, but it's not that bad... it does look like you're getting quite a bit of blow-by and stuff out of the valve covers, but it's nothing I'd be too alarmed about. that's normal wear and tear on a car with 100k+ miles.
Old Dec 27, 2003 | 02:41 PM
MP3Car's Avatar
okay! Thanks guys!
Now I gotta go find some new fuel hose! heh... the hoses going to the rails were so hard there was no way to get them off without mutilating them. Oh well.... isn't car work fun
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
foodmanry
Sep 24, 2015 12:02 PM
bumpypickle
Sep 19, 2015 01:07 AM
Mahmuth
Sep 17, 2015 11:45 AM
ag90fox
Sep 9, 2015 12:22 PM
