What is the normal Cruising RPMs?
Old Jan 2, 2004 | 05:05 PM
FlipMaxima's Avatar
I have a 93 se 5spd that I just got. I took it on the highway and noticed that the rpms at cruising speed 120km/h was around 3000rpm. I talked to a friend about it who has a gxe and he says he does 100km/h (60mph) at 2000rpm. So I'm wondering if this is normal, and if it isn't, does anyone know what it could be and how to fix it?
This has been buggin me for a while
Old Jan 2, 2004 | 05:10 PM
90SEBlack's Avatar
No i believe that 2695rpm should be 65mph anyone who has there speedo apart can tell u i dont remember exactly but when i had my speedo apart i could see that it said the conversion on it I think it was 2695rpm = 65mph but not too sure , It says it on the actuall speedo around the outside but i u cant see it unless u have it apart . But at around 70 mph 3000 isnt that high are engines are designed to run hot and at higher rpms.
Old Jan 2, 2004 | 05:31 PM
subs1000w's Avatar
i know im at 4000 at 100mph so that translattes into about 3000 at 75 mph
maybe your tach or speedo is not accurite
Old Jan 2, 2004 | 07:05 PM
AscendantMax's Avatar
first off, punctuation is your friend. don't know if my auto can relate but i'm at around 2500-2600 while going 70 mph (~113 km/h)
Old Jan 3, 2004 | 08:21 AM
90SEBlack's Avatar
ya after further expection i agree im at around 2500 at 70mph however if i disengage my OD then it rises to around 3100 so i would check to make sure that ur OD is engaged because it should be around 2500 - 2600 as Fosgate Fan said
Old Jan 3, 2004 | 08:41 AM
MrGone's Avatar
autos have taller gears than 5spds, plus a locking torque converter.
I forget what mines at, but I normally do about 85 on the way to school, I think its about 3300rpm.
(thats funny, I do 85 on the way to school. maybe I should slow down? )
Old Jan 3, 2004 | 11:18 AM
90SEBlack's Avatar
naaa that sounds about right for the ride to school in the morning, and around 90 - 95 on the way home when your more alert. lol
Old Jan 3, 2004 | 11:21 AM
Paul89SE's Avatar
If i'm going 75 MPH it's right around 3000 so that sounds right to me.
Old Jan 3, 2004 | 11:34 AM
90SEBlack's Avatar
give or take, lets just say that it not bad thats prolly in the given range of acceptable rpm's
Old Jan 3, 2004 | 11:36 AM
MrGone's Avatar
the funny thing is i'm more alert on my way to school, then sleepy on my way home,
plus sometimes I hit 105 on the on ramp just because I like to run the gears, the crappy part is having to slow down because the car just wants to keep climbing
Old Jan 3, 2004 | 11:37 AM
MrGone's Avatar
my moms subaru does almost 4000rpms before she hits 90mph... its sad
Old Jan 3, 2004 | 11:47 AM
90SEBlack's Avatar
What gear u hit 105 in , I know that with my auto i hit 115 (well on the speedo prolly actually only 107) it shifts into another gear and drop the tach to 4000 and climbs back to 6 and barries the speedo at 125 at around 5,000 5,100 so i figure a 90 auto top speed is around 130 135 , Anyway what gear is it sroping into at 107 i can count it going threw 4 before it hits that gear my buddy said its the OD gear always wonderded what gear that was
Old Jan 3, 2004 | 12:25 PM
MrGone's Avatar
I dont remember what gear I was in, I'm tempted to say 3rd, maybe forth? Kind of sad that I dont know.
I can tell you that in my old 93 SE Auto I hit 115mph with (I think i was around 5000-5500rpm) in 3rd gear, so I had pleanty to go.
Overdrive is simply 4th gear. In my auto I could take first gear to ~40mph, second gear to ~80mph, and never reached the top of 3rd.
Automatics have taller gears that 5spds, so they can technically have a higher top speed.
Old Jan 3, 2004 | 12:42 PM
90SEBlack's Avatar
ya those are my same shift points and anyone else who has barried theres will tell u 3rd is done at 115 on an auto and then i guess its 4 or OD and dunno what that goes up to ull have to find some one with a 145mph speedo
Old Jan 3, 2004 | 01:07 PM
MrGone's Avatar
Are you talking about the engine running out of guts, or the engine red lining? I'm not sure if VG gears are the same as VE's, but I had plenty of engine left in 3rd gear at 115mph. That was over a year and a half ago in my old car. Also VE's have an extra 500rpm on VG's (maybe alittle more).
just curious.
Also Antonthegrey has a 145mph speedo in his car and he's topped it out, he has an 89 5spd. Also the gauges arent too accurate that high, so if you want a true reading get a or maybe a Apexi RSM (anyone know if thats accurate?)
Old Jan 3, 2004 | 01:16 PM
90SEBlack's Avatar
the only thing that i know of to be accurate to the .2 of a mph is a gps.
Old Jan 3, 2004 | 03:55 PM
eric93SE's Avatar
My VE auto is at 2150 @ 70mph
ve powa
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
