newbie here
newbie here
hey whats up guys....just wanted to say hi....i have a 90 Maxima SE...automatic...yea it sucks but its cool...im currently cooking up a turbo kit...mainly composed of z31 parts due to the similarity of motors...just need my injectors and i can start gettin everything together.....i will post pics of my car whenever i get em....but in the meantime...i hope you guys like having me here
oh noes!
I say build the setup first, then worry about injectors and all that snazzy stuff after you get it running with a turbo on it. You can run ~5lbs of boost on the stock motor with with out any real issues (VG that is, and thats what I've learned from alittle research).
oh, and you'll probably get really alot of pic requests because with out them your just another newbie wanting to turbo a 14 year old car, and now pics of just parts arent enough (hence why I said get the fabrication done). oh, put a cooler on that tranny.
yea i got tranny cooler i got all the parts needed to turbo all my gauges fuel controller...the works...i do my research instead of posting "i want a turbo how do i do it" i just need my injectors so i can bolt everything up and then ill take pics
oh boy good luck, the info is out there if you search, and before you ask , yes search works you just have to donate, so donate and youll find all the info you need trust me.
let me ask you..
- what size turbo are you running?
- wet or dry center section?
- what A/R and compressor?
- what size fuel injector?
- what fuel pump?
- what are you going to do w/ the coolant hoses/pipes that will hit the xpipe?
- what are you going to do w/ the maze of vacume and coolant hoses that perfectly hits the xpipe?
- what fuel management set up are you going to run?
- oil lines for the turbo..how are you going to plumb that in?
- where on the oil pan are you going to tap the return oil line?
- internal or external wastegate?
that should keep you busy. let me know when you have it figured it out.
JMag90
08-25-2015 09:17 AM
ed571
12-29-2000 08:04 PM
