Need help deciding on new front brake setup...
Old Jan 15, 2004 | 12:47 PM
  #41
shoult's Avatar
Originally Posted by Gjohnson
Matt, school me! Why should I not get drilled rotors, or drilled and slotted rotors.
That's easy. Because drilling and/or slotting a rotor puts stress risers into the metal which will lead to quicker cracking of the rotor.
And yes, the racers use them. But they are also willing to replace them every few hundred miles.
Yes, Porches come from the factory with "drilled" rotors. But Porches rotors are not drilled, they are cast with the holes in them. This drastically reduces the occurance of stress risers.
Any other rotor you see started life as a blank and was machined to have holes or slots.
On the street you will never know the performance difference.
All your getting with holes and slots for a street car is bling (all lower case, no punctuation, single bling cause it ain't that cool or special anymore).
Old Jan 15, 2004 | 12:56 PM
  #42
Jeff92se's Avatar
I'm needing a caw
Old Jan 15, 2004 | 01:07 PM
  #43
Paul89SE's Avatar
Enough said Jeff, very tight! Gotta love the Cobra wheels.
Old Jan 15, 2004 | 05:32 PM
  #44
Gjohnson's Avatar
Originally Posted by Jeff92se
Wow
Old Jan 15, 2004 | 06:49 PM
  #45
jaymez619's Avatar
Since you appear to be new here. I'll give you a tip.
www.internetautomart.com
If it ain't listed ask, They can probably get it anyways
Rumor has it he's a nice guy
That's where I was checking for the Brembo fronts. After shipping, it'll be about $100/pair. I'm still open to suggestions for which pads to get. I'm leaning towards Raybestos QuietStop up front unless some1 gives me good reason to do otherwise. I might just go with some cheaper Raybestos pads in the rear.
Thanks in advance. Because of this site, I'm keeping my sight and downloading less ****. That should be my sig.
Old Jan 15, 2004 | 08:19 PM
  #46
internetautomar's Avatar
mod or sell?
are you implying that I should add the raybestos pads to the site.
I know I've been slacking off lately.
I just revamped my whole import control arm section
Old Jan 16, 2004 | 02:53 PM
  #47
Gjohnson's Avatar
Jeff92se, do you have a link to another thread, that can let me know what all is need for the big brakes.(Cobra, right?) I can't search because I have donated and I was going to donate, but they disabled it for the moment.
Unless you just want to post the answer.
Old Jan 17, 2004 | 12:44 PM
  #48
pezking4's Avatar
I'm very pleased with my slotted Brembos and Axxis MetalMasters. If I did it over again I would proably just get the blank Brembos, but I got a good deal on the slotted rotors. I used the Motul 600 fluid that Stillen sells; good fluid, but kinda pricey.
I'm about to do brakes on my 328i this week and I'll be using all ATE products. You may be interested in using ATE's super blue brake fluid; its so much easier to bleed you brakes with a different color fluid.
I have purchased brake parts from GR Racing , Stillen , and Taylor Automotive . I have had great experience with all of these companies.
Old Jan 20, 2004 | 10:48 AM
  #49
Jeff92se's Avatar
I'm needing a caw
You need 13" Cobra rotors (ie.. 1998'), hub rings to mount them(from Candiman), two brackets from me, additional set of bolts/nuts to mount the bracket, some new SS lines, some 30mm aluminum 300zx calipers, and some 17" or larger wheels that will clear everything.
http://forums.maxima.org/showthread.php?t=275563
http://forums.maxima.org/showthread.php?t=244197
Old Jan 20, 2004 | 11:04 AM
  #50
mod or sell?
I sell those rotors along with ones for just about any car
Matt93SE
May 24, 2019 02:58 PM
03VQMAX
Sep 25, 2015 04:19 PM
homeyclaus
Sep 3, 2015 06:15 PM
seesole
Aug 26, 2015 11:22 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
