Driver's Door Hinge Problem
Old Jan 6, 2004 | 08:33 AM
Alan in Dallas's Avatar
I hae a 91 GXE. It appears that the bushings in the hinge for the driver's door are worn such that the door hits the vertical column when closing. Is there an easy fix for this? THX, Alan
Old Jan 6, 2004 | 09:07 AM
Matt93SE's Avatar
STFU n00b!
sure.. replace the hinges. they're about $12 each from the dealer.
you have to pull the driver's side fender to get tot he bolts, but it's not that bad. about 12 small screws and the fender comes off... then just leave the door closed and replace one hinge at a time (so you don't let the door flop loose on that end).
Then you just need to put some shims around the door or have a helper hold the door in place so you can realign it... just loosen the bolts on the hinge, move the door a bit, then tighten them. do that unitl the door closes properly and you're done (except for putting the fender back on)
it's probably a 2-3 hour job for a first-timer, but doesn't require anything fancy for tools.. just 10,12,14mm sockets and wrenches I think.
Old Jan 6, 2004 | 12:27 PM
rrrfoma's Avatar
don't forget to paint new hinges (x2) before putting 'em on
MAXSE5SPD
Sep 17, 2022 04:00 AM
AcuraLegend
Sep 22, 2015 04:22 PM
maximusrising
Sep 2, 2015 09:55 AM
Hailstatejig
Sep 2, 2015 06:52 AM
A32goldylocks
Sep 2, 2015 06:39 AM
