Rattling from engine when key turned to ON only
Old Jan 8, 2004 | 10:48 PM
drstillpatient's Avatar
i've been hearing this for some time now but never thought much about it. Sometimes (specially when first time in the morning) when i turn the key to on position, and i hear the fuel pump making the whiirrrrr/hmmm sound, i hear a rattle from the engine. its a short rattling sound for like 2 seconds, its like something loose moving around. and i been hearing it since i changed the spark plugs.
The car's been starting rough too lately. but after starting the engine runs perfect. no missing or anything.
Old Jan 8, 2004 | 11:58 PM
mtcookson's Avatar
does the rattle make noises in time or are they sporadic?
i.e. * * * * * compared to
just think of the * as a tick per *
Old Jan 9, 2004 | 12:08 AM
no sequence....just sporadic...but very short. sounds like something loose being bounced around inside while something else is moving beside it
Old Jan 9, 2004 | 12:12 AM
mtcookson's Avatar
only thing i can think of is the fuel system doing something weird or there's a relay up there that is freaking out. i'm not sure what else could be making noises since the engine isn't even running.
Old Jan 9, 2004 | 08:14 AM
rcy's Avatar
rcy
Why don't you get someone else to turn the ignition on, while you stick your head in the engine bay and try to narrow down exactly where the sound is coming from. It has to be something electrical or fuel related since the car isn't even running. Do you have ABS? Maybe it's the ABS motor doing a self check?
Old Jan 9, 2004 | 09:21 AM
rrrfoma's Avatar
you'd be laughing but it might be a stuck relay for something (not relay itself by all means) if it is freezing outside like -35C in Ontario.
headlights relay was stuck on my car this morning
Old Jan 9, 2004 | 11:12 AM
does the distributor rotor spin as well to find the crank shaft position? when key is turned to ON?
Old Jan 9, 2004 | 10:26 PM
mtcookson's Avatar
nope, distributor is mechanically ran off of the camshaft. the rotor won't move without the engine.
MAXSE5SPD
Sep 17, 2022 04:00 AM
intimidator
Sep 5, 2015 07:23 PM
TheMafia
Sep 4, 2015 08:26 AM
iflexsteel
Sep 2, 2015 08:04 AM
A32goldylocks
Sep 2, 2015 06:39 AM
