muffler on a ve
Old Jan 15, 2004 | 11:44 AM
icepick's Avatar
muffler on a ve
i have a ve 94
and i put this muffer on it
http://cgi.ebay.com/ebaymotors/ws/eB...category=33636
it sounds real nice but its to loud for my test
so now i was thinking of custom this in
with a good looking tail pipe chrome or pouder coated black some thing nice
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2454363399
guys give me any ideals thoughts
so on
also i want a remote start / alarm/ keyless entry
but i was thinking if i install on then my cruse control will stop working
reason being when you hit the clutch it kills the cruse control
so if i by pass the clutch to be on all the time for the remote start the cruse control will not activate
thanks guys rob
Old Jan 15, 2004 | 12:13 PM
mtcookson's Avatar
don't get a 40 series. those things are waaayyy too loud (at least for me). they have very loud interior volume which bites when traveling on the highway.
Old Jan 16, 2004 | 06:50 AM
icepick's Avatar
any more ideals >remote start<
Old Jan 16, 2004 | 06:56 AM
Michael's Avatar
Back in a 3rd Gen.
1. Get a Dynomax super turbo muffler
2. You do not disable your clutch all the time. There is a way to wire it up to work CORRECTLY and will not mess up your cruise. 2a. take it to a professional to get it done correctly.
Old Jan 16, 2004 | 08:13 AM
icepick's Avatar
you not supose to put remote start on a stick thats what they told me
when i went to a pro. and i know what im doing just alittle confuse. about the clutch
Old Jan 16, 2004 | 08:14 AM
subs1000w's Avatar
the other thing is ther are 2 pin switches for the clutch one for all the way out one for all the way in.
i think you only need to bypass the one thats all the way in and the other one will still alow the cruse control to work
i have the wiring diagram at work to use a relay to bypass it the right way but ill have to go dig it up and post it
Old Jan 16, 2004 | 08:16 AM
subs1000w's Avatar
there are places that do install them on sticks but at citrcuit city where i work we wont because we dont carry any remote starts that are DESIGNED for them
Old Jan 16, 2004 | 08:19 AM
Nothingstoofast's Avatar
i install remote starters for a living. a shop wont do a manual cause of the liability. i have a starter on mine and i have a manual. you just have to use a relay to bypass the clutch switch only when the remote starters is cranking. NOTE: remember to leave it in neutral... i have had to chase my car before lol.
Old Jan 16, 2004 | 08:34 AM
poorcollegeboy's Avatar
you can also connect a relay that powers the starter wire only if it's in neutral (there should be a neutral sensor wire at the ECU... mine is solid brown)
Old Jan 16, 2004 | 08:40 AM
maxman92's Avatar
All you have to do is jump the pigtail that goes to the neutral saftey switch. Then you will no longer have to press on the clutch when you start the car. Just be VERY careful to leave the car in neutral!
This is the way I have my car set up.
Old Jan 16, 2004 | 10:56 AM
icepick's Avatar
where is the neutral saftey switch under the dash ?
Old Jan 16, 2004 | 05:52 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
i just bypassed the switch - i NEVER leave my car in gear
Old Jan 16, 2004 | 11:13 PM
«§»Craig B«§»'s Avatar
There is a correct and completely safe way to wire a remote starter to a car with a manual transmission. I've done it on several cars including my own. the car comes built in with a neutral sensor at the ECU. If you use this wire, you can use some relays to wire it so that the car will not even attempt to remote start if left in gear. Also, you dont need to bypass the clutch all together. Just run a wire to the output side of the clutch switch so that it gets power when you want to remote start. There are two clutch switches - one for cruise control cancel and another for starting so you wont have to worry about that.
Old Jan 17, 2004 | 12:10 AM
davebond007's Avatar
Enjoy.
Old Jan 18, 2004 | 07:22 PM
icepick's Avatar
so whats the best thing to do bypass the 2nd clutch switch or run a relay form the remote starter
Old Jan 18, 2004 | 08:39 PM
if you want to do it the right way, run a relay to the switch
if not, bypass it
Old Jan 19, 2004 | 08:17 AM
icepick's Avatar
does any one have any idea of a good alarm prestegie ???
thanks
Old Jan 19, 2004 | 08:40 AM
internetautomar's Avatar
mod or sell?
DEI makes good units as does crimestopper.
of course I sell both as well as the "prestige" which is audiovox
Old Jan 19, 2004 | 12:23 PM
icepick's Avatar
What Dont You Sell
What Would You Recomend
Old Jan 19, 2004 | 12:46 PM
mod or sell?
a dei unit, but nube is more knowledgeable on alarms than I am.
Turbonut
46
Oct 21, 2015 08:28 PM
iflexsteel
Sep 15, 2015 03:37 AM
TheMafia
Sep 4, 2015 08:26 AM
mpbclutch33
Sep 1, 2015 09:24 AM
erictown
Aug 20, 2015 08:01 AM
