just installed tranny, think i got a problem, help please
Old Jan 17, 2004 | 03:26 PM
joesmaxima's Avatar
whats up guys, just put my 3rd tranny in and this ****ing one has a problem i think. It makes a knocking noise when in idle and gear, but when you push clutch in the noise goes away. The knocking goes faster as you climb up the RPMs , at like 4k it is really fast. What do you guys think ? im ****ed
-joe
Old Jan 17, 2004 | 05:19 PM
joesmaxima's Avatar
Old Jan 17, 2004 | 05:24 PM
subs1000w's Avatar
if you mean at idle and in nutral i have the same knocking or ticking and it goes away when i push the clutch in
i think its imput shaft bearings
Old Jan 17, 2004 | 07:10 PM
bobbydigital450's Avatar
Could be the input shaft bearing. If i remember right, i think mine was doing the same thing. About $150 in parts and anywhere from 500 - 1000 in labor is what ive heard.
Old Jan 17, 2004 | 07:42 PM
mtcookson's Avatar
yup, input shaft bearing. mine is going out as well (2nd one). you can get the parts pretty cheap. the bearing and seal should cost about 50 bucks or so from www.drivetrain.com
Old Jan 17, 2004 | 07:47 PM
subs1000w's Avatar
i think im going to order them and install them the next time i have my tranny out (which for some reason seems to be every few months) i will also be replacing the 3rd gear syncro
what do you need to change the bearings and syncros is there a special puller or just a press
Old Jan 17, 2004 | 07:57 PM
mtcookson's Avatar
you have to use a press to get the bearings off.
Old Jan 17, 2004 | 08:38 PM
joesmaxima's Avatar
thats bull****, now i have to take my trans out again. Or is this on the actual driveshaft? Sorry im used to RWD cars like my rx-7 hehe thanks for the help bros
joe
oh and will driving the car hard **** up anything bad ?
Old Jan 18, 2004 | 06:36 AM
joesmaxima's Avatar
Old Jan 18, 2004 | 01:35 PM
subs1000w's Avatar
joe
yes oyu have ot pull the trany to fix it
and driving the car hard will not really hurt anything i still drive mine normal (very hard) it may make it alittle worse but mine have been the same for the last month
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
Cotozic
Jun 28, 2017 08:01 PM
sc10692
Aug 9, 2015 09:37 AM
kirkhilles
Aug 8, 2015 10:53 AM
