Regulator or Motor
Old Jan 23, 2004 | 07:28 AM
HSVMaxima's Avatar
Regulator or Motor
When I try to roll the passenger side rear window down, I only hear a loud noise like something is stuck in a gear. Is this a window regulator or window motor problem?
Also, my antenna mast is fully extended but when I turn the radio off I only hear the motor. Do I only need to buy the the antenna part?
Thanks.
Old Jan 23, 2004 | 08:00 AM
sublunary's Avatar
its most likely your regulator. they are notorious for failling. ive replaced three of mine. There is a wire that come loose which is probably the noise you hear. is you window up though? when mine broke the windows fell into the door.
Old Jan 23, 2004 | 10:18 AM
internetautomar's Avatar
mod or sell?
If you hear the motor going then 95% chance it's you regulator.
I sell regulators and motors
HSVMaxima's Avatar
Actually, I bought the car knowing the window was damaged, so yes it was up. Now, I'm trying to fix it.
Old Jan 23, 2004 | 10:20 AM
HSVMaxima's Avatar
The sound I'm hearing is an awful grinding noise not a normal motor sound like I have from the antenna. Just wanted to make sure I shouldn't buy the motor too.
Old Jan 23, 2004 | 10:23 AM
sublunary's Avatar
take the door panel off and you can see if the motor is working but im with him its the regulator probably
Old Jan 23, 2004 | 10:46 AM
mod or sell?
The grinding noise is probably the wire cutting into the guides.
I know that some people have been known to stick all sorts of things in the door to hold up the window.
I had a match book holding up mine, another guy has wood holding up his,
Old Jan 23, 2004 | 10:59 AM
sublunary's Avatar
i hear that, i used some foam when one of mine went bad while it was raining, nice
Old Jan 23, 2004 | 11:25 AM
MaximamixaM's Avatar
Back to the antenna. I think 4dsc.com has a write up on replacing it. Your motor is ok. It's just that the antenna is pulled down with a motor and a pulley, and I think there is a plastic part that breaks. I think your motor is ok. Anybody know of any good fixed mast antennas that look good and don't retract?
Old Jan 26, 2004 | 08:13 AM
sublunary's Avatar
i put a jetta type antenna on after my stock one broke. it was super cheap and gets fine reception. i think it looks good to but it could look really bad if your car isnt black cuz it won't blend in. oh btw, i put it where the old one was i don't like them on the roof like they are intended.
Old Feb 15, 2004 | 06:37 PM
moharv's Avatar
regulator and antenna
WOOHOO!! Thanks for answering BOTH of my questions/problems!! This board is GREAT!!!
Old Feb 15, 2004 | 08:25 PM
bansheenomore's Avatar
The grinding is probably your cable wound up on your lower pulley. Its grinding on itself. Very common for any cable drive system. I replace these alot in all different cars. BTW Honda's are the worst for regulator problems!!
aw11power
Oct 10, 2021 04:57 AM
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
