rear sway bar links broke
Old Jan 25, 2004 | 01:43 PM
ChrisCheezer's Avatar
hey, i had my addco rsb on for almost 3months now, and i just noticed today a *harsh* sound generating from the sway bar support braket on the left (the little bars that hold the "U" brakets on" I looked at it and one part is "pealing" off the frame of the car. every time i hit a small bump it rattles.
-question- how long can i ride like this, cuz its really cold out and i can't work in the cold..
thanx in advance
Old Jan 25, 2004 | 01:45 PM
Pervis Anathema's Avatar
http://www.mattblehm.com/suspension.html
Suck it up and pull the bar. I did mine in 15 minutes and just threw it in the trunk until the new links get here.
Old Jan 25, 2004 | 02:38 PM
what do u think will happen if i leave it on? do u think it could hit the wheels or anything?
Old Jan 25, 2004 | 02:53 PM
D-sta's Avatar
Its $40 get them mine broke also
Old Jan 25, 2004 | 03:21 PM
yeah i know that.. im going to pick them up real soon
BUT CAN ANYONE TELL ME.. if it will harm my car if it stays on broken?
Old Jan 25, 2004 | 03:22 PM
Jack.'s Avatar
mine is still on, with one link nothing wrong there, just don't go through the twisties at 60 and you'll be fine. My links I bought from Matt should be here monday I think. I'm excited.
Old Jan 25, 2004 | 03:24 PM
D-sta's Avatar
Chris it should be fine until you get the replacement. Are you getting matt's or from the dealer?
Old Jan 25, 2004 | 03:54 PM
matt's i hope, do the old links screw into the car???
Old Jan 25, 2004 | 04:42 PM
Yes. Matt said he ships them with self tapping screws. My understanding is that you just cut the old brackets off of the frame, center punch where you want the new screws, and drill two small holes. Then you bolt the new ones on, connect them to the sway bar, and your done. Easy!
Old Jan 25, 2004 | 11:07 PM
Matt93SE's Avatar
STFU n00b!
Correct. you just need to cut/grind/remove the factory bracket on the frame, then I send some stronger angle iron pieces with self-tapping screws with the kit. just mark the holes and drill with a 7/32" drill bit. (they're like $1 at any hardware store)... then just mount the new angle iron onto the frame rail, then the rest of the parts bolt right on just like the factory piece. all hardware is included. all you need to do is cut the old bracket off the frame.
For those of you who don't want to do the self-tapping screws, you can take them to a muffler shop and have them welded on... It's no necessary though- mine have been on the car for about two years with the self-tapping screws and haven't come off yet.
Old Jan 26, 2004 | 09:07 AM
np
ok sounds good, i hope u got the million and a half e-mails i sent u
i'm going to pm you with a question..
thanx again
ef9
Aug 27, 2015 07:21 AM
seesole
Aug 26, 2015 11:22 AM
Dasmith
Aug 25, 2015 10:15 PM
Maxboy23
Aug 20, 2015 09:33 AM
MaxStock
Aug 14, 2015 10:03 PM
