Helo motor acting up
Old Jan 26, 2004 | 11:55 AM
95se5spd's Avatar
The other day i did a compression test on my car and i bumped the timing. in the process i messed up two coil packs but didn't pay much attention. The next day the car started to act weird it would shut off on me randomly like if somebody turned the ignition off at any time. Anyways i went and bought the two coil packs but the problem is still there. I got frustrated and disconnected one of the coild packs and the problem went away. The car had a misfire but at least it wansn't turning off. I was thinking maybe bad AFM or a bad coil pack connector. What do you think i need to solve this problem ASAP
Old Jan 26, 2004 | 01:12 PM
icepick's Avatar
check for spark on all the pistons then check the crack angle sensor play with the timing also there could be a vaccum leak mafs could be lose that happen to me
Old Jan 26, 2004 | 08:13 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
its usually the last thing you think of.....usually its dumb stuff like a loose maf that would cause thats
Old Jan 27, 2004 | 06:45 AM
95se5spd's Avatar
I have checked every connection and nothing seems to be wrong. Could the AFM do this?
Old Jan 27, 2004 | 08:23 AM
eric93SE's Avatar
How did you mess up two coils?
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
zmcneely13
Sep 26, 2015 02:26 PM
