How bad is this?
Old Jan 27, 2004 | 01:51 PM
94M@X's Avatar
How bad is this?
Front left wheel:
(I get noise only under heavy acceleration)
Replace Axle or just CV boot? Think thats what its called?
Gil
Old Jan 27, 2004 | 02:11 PM
Michael's Avatar
Back in a 3rd Gen.
replace axle
Old Jan 27, 2004 | 02:14 PM
Jeff92se's Avatar
I'm needing a caw
It's not that bad, but if you are getting noise out of it, might as well replace it.
Old Jan 27, 2004 | 02:17 PM
94M@X's Avatar
Will there be a problem if I change only one. The front right is also leaking (very little). I would like to do both but there are some limiting factors ($$$$$). Will changing only one cause problems?
Thanks again
Old Jan 27, 2004 | 03:17 PM
broncoguy's Avatar
Changing just one shouldn't cause any problems in and of itself. If you want to buy some time, you could try replacing the boot with one of those split versions. They are a pain in the a$$, but they'll keep the grease in for a little while until you can save up for new axles. Aftermarket axles aren't that much- maybe $50-$60 each if you can do the work yourself. The split boots are like $10 each. I hate them, but I've used em in a pinch..
Old Jan 27, 2004 | 05:13 PM
davebond007's Avatar
Or fix it with some ghetto wire.
I'd vote to replace it though.
Old Jan 27, 2004 | 06:05 PM
MrGone's Avatar
drive around in full lock circles. if it clunks, replace it, if it doesnt, fix the boot.
I'm poor too . Granted I'd have better peice of mind just replacing them, but still what works, works.
Old Jan 27, 2004 | 06:54 PM
94M@X's Avatar
Thanks for the info guys!!
Old Jan 28, 2004 | 05:14 PM
StRacer718's Avatar
Just replace the axle. Nothing is worst than letting your axle break on you, becomes much more exspensive from the damage caused to the rest of the car.
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
