Heater Valve ??
Old Feb 2, 2004 | 12:29 PM
1994DKGRN's Avatar
Heater Valve ??
Hello experts...
In my wife's 1994 Maxima, cold air (and I mean cold) blows out of the dash vents (even with the dials closed) while the heater is on. Hot air comes through the dash vents on top as well as down behind the console (radio), but the air vents on the front have cold air coming out (even with the little up-down switch next to the heater controls in the down position - what is the purpose of that switch anyway?). What could be causing the cold air to blow through the front when hot air is coming out on top? Is the heater control valve bad? Is it the little switch I mentioned that has two positions (up/down) with the blue-wavy lines at the top position? I assume the purpose of that switch is to "block" airflow through the front vents but it doesn't seem to work - maybe that's the problem?
Mark
Old Feb 2, 2004 | 12:31 PM
internetautomar's Avatar
mod or sell?
the wavy line lever should be down.
it is a fresh air control
Old Feb 2, 2004 | 02:42 PM
1994DKGRN's Avatar
We've tried the lever up and down, it didn't make a difference - cold air still blows through.
Old Feb 2, 2004 | 07:34 PM
Michael's Avatar
Back in a 3rd Gen.
the cable or lever is probably broke then. Look under the dash adn there will be a lever with the cable going to it (nothing else around it...not motor or anything). see if you can move it by hand.
howardis
Dec 11, 2019 06:10 PM
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
tardrex
Sep 11, 2015 07:35 PM
