Am I Leaving Anything Out
Old Feb 3, 2004 | 09:10 PM
bansheenomore's Avatar
Last post failed for some reason. lets try again!!
New VTC Kit $28ea. Those dont look anything like what I expected.
New Knock sensor $135
New Full Gasket kit $212
New set Exhaust Studs, nuts, washers $30
Mad Mad That Don,t Rattle $PRICELESS$
Let me know if there is anything that I missed or need. Is there any thing I should look for or replace while I'm there??
Old Feb 3, 2004 | 10:06 PM
harrymay's Avatar
check piston rings, i think you had the timing belt replaced,
maybe a water pump too, itw worth doing while your digging around.
Old Feb 3, 2004 | 10:25 PM
Mine's an SE I have 3 expensive chains. They only have 75,000 miles. They better last longer than that.
Old Feb 3, 2004 | 10:26 PM
MrGone's Avatar
You do not need to pull the heads. That will save you atleast $100 in parts.
btw, thanks for the list, I'll be doing this stuff on another car in a few weeks too, hehheehe (well I didn't need to know the parts, but blah). Theres going to be 2 northwest maximas torn apart soon (and probably 2 more this weekend, lol)
Old Feb 3, 2004 | 10:30 PM
harrymay's Avatar
im writing that down too, im starting to think some preventative maintenance could do a good thing,
Old Feb 3, 2004 | 10:32 PM
I looked up the VTC replacement on ALLDATA. They actually recomend that you remove the head. That way you can clean out the oil galleys. There is also a jet in the bottom that should be cleaned out.
I need to remove broken studs too. I might need to remove the head. The only way Nissan had the Gaskets was in a kit. Pretty much the same price seperate either way>
REDinLV
Aug 15, 2024 12:30 AM
Kingofmaximas24
Nov 12, 2015 04:40 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
carid
Sep 17, 2015 05:00 AM
