Gas Smell
Old Feb 17, 2004 | 09:33 AM
VDOG's Avatar
Gas Smell
On some mornings, when I start my car, I turn the heater on, and gas fumes come of of the vents, until the car gets warm. Then it goes away.
Have not found any leaks.
Old Feb 17, 2004 | 09:37 AM
Jeff92se's Avatar
I'm needing a caw
Your rubber fuel lines are leaking. Cold = shrinks and leaks. Warm = expands and seals. Go to an auto store and buy FUEL INJECTION hose in the closest SAE inch size. Then size/replace the fuel lines from the fuel filter to the rail. Also replace the line that feeds fuel to the rear injector rails. Front side of the engine.
Old Feb 17, 2004 | 09:42 AM
VDOG's Avatar
Thanks, that was simple. I probably would have gone to the dealer for that.
Old Feb 17, 2004 | 09:44 AM
Damonb's Avatar
Speaking of fuel line, anyone know what size they are? I think the rail - rail is a smaller size than the filter to rail size if I am not mistaken.
Damon
Old Feb 17, 2004 | 09:50 AM
Jeff92se's Avatar
I'm needing a caw
It's all the same size. Just take a piece of line and match it. Relieve the pressure first though.
Old Feb 17, 2004 | 10:25 AM
internetautomar's Avatar
mod or sell?
what, you don't what him to have a flammable shower?
Old Feb 17, 2004 | 10:58 AM
Damonb's Avatar
been there done that... was replacing someone's fuel pump and he was supposed to releive pressure in the system, and dumbass me didnt check first.
<Reach out hand, yell for water, hope someone drags you to the hose>
I just swapped pumps on the 92SE, releived all the pressure but the drain anti drain back valve is so damn good that all the fuel that was in the lines above the tank and below the rail drained out all over the bench inside the car, I gotta get in there with some soap and water big time.
Damon
Old Feb 17, 2004 | 03:41 PM
Polska Hick's Avatar
Fuel Smell
Hehe, I had the classic gas smell on those cold cold mornings. Almost brought it to the shop, then out of luck saw it pouring out of the fuel rail. Turns out, it was an incredibly simple problem. The rubber hose connecting the fuel rails on each side was leaking at the contact point between it(the rubber line) and the metal fuel rail, simply because the clips weren't screwed down tight enough where they meet(from a fuel injector replacement from the previous owner). So all that needed to be done was tighten them. Easy right? WRONG. I had to take off the entire manifold down to the fuel rail to tighted 4 screws, rediculous amount of work just to tighten 4 screws. Wasn't that hard, but took about 50 bucks in gaskets and about 7 hours of labor. Sorda makes me wanna beat the crap out of the guy that did the fuel injector replacement...
Dont be afraid to email me any questions about the procedure if you're having the same problem, Polskahick@hotmail.com
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
