Power Steering Belt Ripping up ? Whats going on here?
Old Feb 17, 2004 | 03:30 PM
sinister's Avatar
Basically, i was replacing all my belts. It was rather easy. Until, i started driving and the power steering/waterpump belt poped right off the pulleys. When i look at the belts it is all ripped up. So i thought that it wasnt aligned properly. So I remove all the belts again replace the belt and put the other belts back on. Thats when i thought everything was ok. it was driving ok and everything. Of course the moment i said it was ok. the belt ripped off again.
Someone please tell me what is going on here?
Any little bit of information counts.
HELP ME PLEASE!!!!
Old Feb 17, 2004 | 03:32 PM
Jeff92se's Avatar
I'm needing a caw
Did you tighten them all to spec? Did you remember to tighten the pulley nut inself as well as adjust the tensioners properly?
Old Feb 17, 2004 | 03:33 PM
sinister's Avatar
Yea I did all of that.
Old Feb 17, 2004 | 03:36 PM
Jeff92se's Avatar
I'm needing a caw
So the old belts worked fine and didn't shred. Only after you messed with them right? Tension way too tight?
Old Feb 17, 2004 | 03:55 PM
sinister's Avatar
u think its way to tight or way to loose
Old Feb 17, 2004 | 03:59 PM
Jeff92se's Avatar
I'm needing a caw
Too loose. Belt won't shred. Just squeek. Too tight might make the belt shred. Especially how fast they got ruined. You just can't crank down on the tensioners and not consider how tight you are making them. It's easy to crank too much as the tensioner bolt doesn't get harder to turn as the tension rises. You have to at least estimate how tight the belt is by how far you can deflect the belt by hand.
lowpost99
Oct 26, 2025 06:53 PM
mikeg75
Nov 30, 2015 05:12 PM
markevans999
Oct 25, 2015 08:27 AM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
