clutch
Old Feb 19, 2004 | 06:13 AM
icepick's Avatar
clutch
do all maximas 3.0 have the same clutch
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2461191279
check that out also how much is a clutch
94 se
whats a good company to go with
Old Feb 19, 2004 | 06:18 AM
Matt93SE's Avatar
STFU n00b!
Old Feb 19, 2004 | 06:30 AM
icepick's Avatar
i did use google and it threw me to ebay
Old Feb 19, 2004 | 06:34 AM
Matt93SE's Avatar
STFU n00b!
common sense says to use other links. google gives many answers, not just ebay.
Old Feb 19, 2004 | 06:56 AM
icepick's Avatar
i know i know
check this out they do
http://www.coximport.com/act/nissan.html#Maxima
Old Feb 19, 2004 | 08:21 AM
internetautomar's Avatar
mod or sell?
or you could look at your friendly neighborhood parts specialists website, as the answer is there as well.
Old Feb 19, 2004 | 08:55 AM
mtcookson's Avatar
84-86 300zx clutch works and in most cases it handles more torque than the maxima ones.
Old Feb 19, 2004 | 09:03 AM
Jeff92se's Avatar
I'm needing a caw
Works for a VE also? That's what this guy has. I think there is a difference because Fidanza has diff p/n for VG/VE. ie.. diff # of PP bolts or pattern.
Old Feb 19, 2004 | 09:21 AM
mod or sell?
The disc itself is the same, but the pressure plate is different.
ALL 3.0 Maximas take the same clutch and it is a Maxima/I30 clutch only
Old Feb 19, 2004 | 09:25 AM
mtcookson's Avatar
i believe the only difference in the fidanza for the ve and vg is the 6 bolt pattern on the vg compared to the 8 bolt on the ve. pressure place bolts should be identical.
i ordered a spec stage 3 clutch for a 84-86 300zx turbo and everything lines up on my vg fidanza flywheel.
be absolutely sure you order one for the 84-86 though. the 87-89 300zx turbo is a 250 mm clutch compared to our 240 mm.
here's a break down
84-86 normally aspirated - 240 mm works on our cars
84-86 turbo - 240 mm works
87-89 normally aspirated - 240 mm works
87-89 turbo - 250 mm does not work on our cars
i just say to get the 84-86 clutch just to be on the safe side and generally the turbo clutches hold more torque than the n/a clutches.
Old Feb 19, 2004 | 09:40 AM
icepick's Avatar
i herd stage 2 and 3 is bad for streat driving
Old Feb 19, 2004 | 09:48 AM
mtcookson's Avatar
stage 2 and 3 on the spec clutches have a sprung hub so it makes street driving much better.
http://www.nipponpower.com/drivetrain/clutch/spec.html
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
