fuel pressure
Old Feb 19, 2004 | 07:53 AM
jakemooremd's Avatar
fuel pressure
Please forgive me as I cannot search.
My 93 SE is dead. I drove to work no problem. It would not start for the commute home. Testing reveals - all fuses intact, gas in tank, nice blue spark, runs 30 seconds with starting fluid then dies. Also about once every few hours when I attempt a start in will run a few seconds and then die. Stepping on the accelerator at this time kills the engine.
I assume a fuel pressure problem, e.g. pump or pressure regulator or something.
I replaced the fuel filter with no improvement. Unfortunately my repair manual depicts a pressure gauge inserted in the line after the fuel pump with simple hoses and clamps. Yet the only guages I can buy have a schrader valve designed to hook to the fuel rail. I do not see a valve on my fuel rail. How else can I test the pressure? Can I unplug the filter, crank the engine and see if I get a geyser of fuel? Do I expect the gas to hit the ceiling of the garage or just trickle out if I do this? How can I test the control valve?
Many thanks.
Jake
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Forge277
Jun 13, 2016 09:26 PM
