spark plugs
Old Mar 12, 2001 | 10:17 AM
rambo91145's Avatar
its time to change maxs plugs. any suggestions on brands. i was thinking about splitfires...is this a good idea? thanks
Old Mar 12, 2001 | 11:06 AM
guido_sst's Avatar
The stock NGK plugs seem to work best the Maxima, especially in the VE30DE engines, SEs are extremely picky about their plugs.
Old Mar 12, 2001 | 12:04 PM
maxmizd27's Avatar
I have Bosch platinum's in mine and they seem to get along. The commercials for Split Fire's sound good, but I've also heard some real horror stories about them. I, personally, would take a chance on them.
Old Mar 12, 2001 | 12:12 PM
maxmizd27's Avatar
Oops!
I mean't to say WOULDN'T take a chance on them. Pay no attention to that man behind the curtain...
Old Mar 12, 2001 | 12:48 PM
Redmax's Avatar
Redlinemax Owner
My car seems to like the Bosch platinums +4 but i've only had them 2 weeks. But the car loved the regular bosch platinums.
Old Mar 12, 2001 | 02:45 PM
Jaybird180's Avatar
I have Autolite, and do not care for them much. The NGK were not available when I needed them most. I had to go with what was available in an emergency situation. I've learned not to stray much from "Genuine Nissan" parts, the hard way.
Old Mar 13, 2001 | 11:01 AM
guido_sst's Avatar
Bosch Platinum +4s
I tried the Bosch +4s in my 93 SE and they missed like crazy, every time the idle dropped it would start missing.
I was really afraid of what it was doing to my engine, as soon as I could I called Courtesy Nissan and ordered stock plugs, it hasn't missed since.
Old Mar 13, 2001 | 11:09 AM
FroMan's Avatar
split fires are a gimic. get the stock NGK's for ~$1.50 each. I don't think that you would notice any sort of improvement beyond a normal plug on a NA engine.
Mario
Old Mar 13, 2001 | 06:07 PM
superdesi's Avatar
Re: Bosch Platinum +4s
How exactly can I tell if my engine starts missing.
What does a "MISS" feel or sound like?
Thanks.
Old Mar 13, 2001 | 11:01 PM
guido_sst's Avatar
The copper NGKs for VGs are $1.50, the platinums for the VE engines are more like $9.50 each!
Make sure you get the correct plug!
Mario
Old Mar 13, 2001 | 11:06 PM
guido_sst's Avatar
Re: Re: Bosch Platinum +4s
Basically, the engine just hesitates as the spark plug misfires. The whole car will probably shake a little, you'll feel it in the seat more than you'll hear it.
I can't really explain the sensation, but if you're parked at a light and you feel a soft of bucking off and on, that's most likely the engine misfiring.
Thanks.
Old Mar 13, 2001 | 11:12 PM
jdonavich's Avatar
Bosch Platinum +4's in my 93 SE and they're great. Bosch invented the spark plug so I think they know what they're doing. I'm sure the NGK's work fine too but I like the 4-electrode design.
-Jeremy
Old Mar 15, 2001 | 07:12 AM
crsmax's Avatar
[QUOTE]Originally posted by guido_sst
[B]The copper NGKs for VGs are $1.50, the platinums for the VE engines are more like $9.50 each!
Can't the platinums NGK's be used in the VG too?
Old Mar 15, 2001 | 09:26 AM
rambo91145's Avatar
thanks to everyone who posted. i decided to try the bosch plat. since that seems favorable to everyone. thanks for the info.
Old Mar 15, 2001 | 08:42 PM
guido_sst's Avatar
Originally posted by crsmax
Can't the platinums NGK's be used in the VG too? [/B]
Theoretically, any plug with the proper gap can be used, I don't have a lot of experience with the VGs, but there shouldn't be any problem using platinum plugs in it.
Old Mar 16, 2001 | 10:51 AM
crsmax's Avatar
Cool. I think I'll test it out... Thanks for the info.
Old Mar 16, 2001 | 11:19 AM
Jeff92se's Avatar
I'm needing a caw
Holy **** man, that car is wrecked beyond belief. I didn't die!?!
Old Mar 16, 2001 | 11:22 AM
hclll's Avatar
Changed plugs for my VG yesterday
Copper NGK's. They work pretty well. I didn't put anti-seize so I smell gas today.
I also found out the stock plugs on my VG is something like "Autolite", not NGK. Why?
Old Mar 16, 2001 | 03:37 PM
eric93SE's Avatar
There is a technical serive bulletin for sparkplugs
Standard type NGK PFR5C-11
HOT TYPE NGK PFR4C-11
COLD TYPE NGK PFR4C-11
I'm not using ngk. I'm using bosch plat. at the auto store
they have two different heat ranges for the bosch plats
posted . So I am now trying the next hotter heat range,
with no big difference.
If you car is heavily modified you might want to try the colder plug instead. but if your mainly stock you shouldnt try this because the plug may foul a little when you come to a stop.
Old Mar 16, 2001 | 05:04 PM
superdesi's Avatar
Re: Changed plugs for my VG yesterday
Could you please expand on the smelling of "gas" by not putting anti-seize compound on the threads of the plugs.
What is the correlation? I have never heard of that before.
Old Mar 17, 2001 | 12:53 AM
guido_sst's Avatar
Autolite plugs are not stock on Nissans, and never have been to my knowledge.
As for smelling gas, applying anti-sieze compound isn't going to keep out any gas smell, something is wrong there.
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
