backing up out of the driveway cause car to shack
how low are you RPMs going when you are backing up? I know that mine shakes in reverse a bit unless i give it gas and its beacuse my RPMs are really low. but if you give it a lil gas it should stop shaking. as far as i know, its just due to low RPMs
Originally Posted by Seyath
The engine idle at low RPM really sucks in the VG. Especially when you are moving very slowly like in reverse. Don't worry about it too much unless it starts happening when you are doing your everyday driving.
Hi,
the shacking times happen when iam at a stop sign or when i slow down for a red light or when i moved forward when iam in a red light.
before it was worse then until i bought the fuel injector cleaner it kind of improve the car by making it less shacking but there is still shacking,
does this ever happen to the ve engine?
this seem really weird,
when i start the car i back up the car, next i go into the street then wait for the red light once it is green i turn and go up a hill, if i keep the speed down to 35 mph i won't smell any egg smell,
when i go around 40 or 41 or use the first gear when i go up the hill i start to smell egg smell,
if i use the first gear but keep the speed around 35mph i don't smell any egg smells,
can a coil cause the car to shack?
the egg smell is common, i have the problem, but i dont pay enough attention to des`cribe it that detailed. and the shaking is because of the idol (sp*) is too low and the RPMS are going down to like 500 or a bit less, mine does it, prolly a lot if not everyones does it. its nothing to worry about
A rotten egg smell usually indicates a plugged catalytic converter.
As for the "shaking": Try raising the idle by a little bit. I can't remember off the top of my head how to do it on the VG. Any haynes/chilton/factory manual will tell you how.
when i first start the car cold the rpm is at the middle betten 1,000 and 2,000 rpm when the engine starts to warm up it goes down to 1,000 rpm and when i rev up the engine the shack goes away a little bit but the shacking is still there but not that much, but it seem a little more smooth then before,
if i go down hill when the engine is cool it seem smooth and quit, and after on a highway the car seem smooth and quit,
That sounds about right, maybe even a little high on the idle side.
How about this: How many miles are on your spark plugs and wires? Also, how does the distributor cap / rotor look? This is a common cause for misfiring which causes shaking.
i got ya covered, im gonna post the idol page on my site
you can find it online or at like barnes and nobles, kinda book stores, it kinda a hit or miss at the store, but they can order it for you. As for the FSM, i dunno but i really want one badly
http://bml94gxe.topcities.com/1-30.gif
http://bml94gxe.topcities.com/1-31.gif
you probably need to save them and then open them
if i rev the engine to 2,000 to 3,000 and let go the idle return back to normal and is fine
which model car us the ecu and the ecm?
Originally Posted by maximagxe90
Hi,
my idle will be okay when i stop for a red,
then once a while the idle will flop up and then go down, it will happen once a while, until i push the gas it will be okay,
i dont understand what your asking for ecu and ecm
here what iam asking for,
89-94 GXE did these model us the ecu or the ecm for the computer?
89-91 SE did this model have the ecu or the ecm for the computer?
92-94 SE did this model have the ecu or the ecm for the computer?
was there any model with the GXE that have the VE30E engine?
was it true that the GXE was a luxture car?
no, no GXE ever had a VE30DE engine, and there is no VE30E engine. And yes the GXE was the flagship of nissan back when it was new. Its considered a 4dsc, which is why the SE have 4dsc on the doors. But the GXe was considered luxury and perfomance all in one and the highest maxima you could buy, along with the highest sedan you could buy before purchasing an Inifniti. Just like new maximas today, even thought they have changed the model kinds ( like SE and GXE, now i belive its SE and SL, but im not sure if its SL or something diffrent)
my max was built at 8/90,
could it be a 91 max?
The ECU and the ECM are the same thing in this context.
hi,
Originally Posted by 89maxSE
The 10th digit in the VIN number will tell you the years. '00 would be Y, '99 would be X and so on. Try it and see what you get
will there is 17th digit in th vin number for my model,
were would i get this info for Y=99 x=99 and so on,
Hi,
Ok, well all that doesn't work. lol I just checked it on my car and it didn't match up. I'll have to ask my buddy about it.
Sorry, but I'll let ya know
Sorry, but I'll let ya knowi did a little research and find out that my max is a 90
i'll give the website so you can find out what your max year is,
http://trucks.about.com/cs/usedadvice/a/vin_decoder.htm
Lakersallday24
Jun 16, 2019 01:35 AM
Team STILLEN
Aug 10, 2015 04:29 PM
