lack of power until 3000rpms on my VG
when i accelerate, normally i would have a good amount of low end torque, but now my cars messing up. now when i give it gas , it doesnt seem to matter how much, it just lazily gets up to right around 3000rpms then roars off. what could be wrong?
Originally Posted by surfermax92
Could be injectors...is the car throwing any codes?
Originally Posted by harrymay
might be a clogged exhaust, bad plugs, bad o2 sensor, bad maf, bad knock sensor, clogged intake, bad cap/rotor, bad plugs/wires, could be a number of things
plugs are platinum NGK with about 10k miles, wires have about 10k miles on them, intake is free, exhaust is free
Originally Posted by acidspit86
where can i get code readings, the car is not OBD-II so i cant use our scanner at school, do i have to bring it to a dealer? how much do all injectors cost?
in all honesty, i never read codes or know one thing about how to check them. and i probably would benefit from knowing. but i strongly urge you to check your injectors: you can do it by running the engine at idle. one-by-one, disconnet then reconnect each injector wire connector. the bad one is the one that is disconnected and the car does not run any differently. if this test proves fruitless, then, more than likely, the injectors are not the issue. BUT, an injector can work partially. but...
if you have this power dropout on acceleration >>>all of the time<<<, then your chances of finding the bad seed, if there is one, are great.
doing this test will perhaps eliminate or confirm possible injector failure.
does it have a hesitation after 3k rpms?
-what color is the exaust?
- is it dumping fuel/black carbon out of that tail pipe when u get this hisitation? (if so its ur O2 sensor un plug it and if it runs a little better then chang out the sensor)
is the car running rich? does it smell like gas? how many miles..
- u need to be more spacific when it comes to car problems that way you could fix it quicker.
Whoah, that's setting you up to waste a lot of money. What if he's got a fouled plug. The injector could be fine, but the cylinder still won't fire. Disconnecting the injector wouldn't change a thing, but it wouldn't be the problem. So now he spends $85 on an injector and $10 on a gasket, and spends an afternoon tearing his intake manifold off, wrestling his injector out of the rail, and putting everything back together. He starts the car to realize that he took out a perfectly functional injector and is no closer (other than knowing one thing that it isn't) to solving his problem. Get a multimeter and check the resistance of the injectors. It could be the difference between a $1.69 spark plug changed in 5 minutes and close to $100 and an afternoon wasted.
thank you, grody. and best of luck acidspit86.
the exhaust is normal color, it smells like gas kinda but my y-pipe has a leak and i have no cat. 120,000 miles.
a bad o2 sensor also turns on the check engine light doesnt it?
also no cat will significantly shorten the o2s life span
i tried pulling the injector power one at a time while the engine is running.... a few injectors made less of a difference than the others. when i pull it, i can still definately tell its running on 5 cyl, but it doesnt chug and make noise as much as the others when i unplug them. could this be a weak injector?
also, can any one tell me what a bad rotor looks like?
thanks
thanks
thanks
thanks
have you done an injector resistance check yet? each one should be between 10-14ohms. if it is a bit above that, you've got too much resistance and the injector is bad.
hmm
resistence on all injectors is 12.5 ohms + or - .2ohms
my max is literally the same way. when its cold it has all the power it should, but when its warm when i floor it in 1st there is alot of lag before it actually kicks in around 3gs. same with 2nd gear car is a dog until 3g area then it gets down. i changed plugs w/ ngk an didnt help. rotor looked good but ill probably get a new one anyway along with plug wires. if that doesnt work i guess ill lean towards o2 sensor.
