VG30 engine problem
Old Feb 24, 2004 | 05:09 PM
chrgdRapa's Avatar
VG30 engine problem
hey guys, i have a 3rd gen 1990 maxima with a VG30 engine in her. a couple months ago, i suddenly noticed that something happened to the engine, and it started sounding weak when idle. and it doesnt put out as much power as it used to. i used to tap on gas and the car would go fast, and now its a lot weaker.
im a newb, i recently got the nissan as my first car and right now, im trying to learn about it as much as possible. my friends and a couple of mechanics dont know what the problem is, but one of the guys suggested that it might be the fuel injection system going bad. and we all think that its running on only 4 cylinders instead of 6.
would anyone know what the problem is or what i should take a look at/replace?
thanks
Old Feb 24, 2004 | 05:30 PM
mtcookson's Avatar
the stock injectors are pretty weak and go out often. that'd be a good thing to look into.
Old Feb 24, 2004 | 11:01 PM
chrgdRapa's Avatar
okay, ill do that
Old Feb 24, 2004 | 11:39 PM
maximagxe90's Avatar
Originally Posted by chrgdRapa
okay, ill do that
Hi,
can tell us what the trim is,
is it a gxe or a se,
if it is the fuel injector,
what you can do is buy fuel injector cleaning solution and put it in the fuel tank and see if that help the problem,
because if you bring the car to the dealer they will charge a lot of money on this kind of car,
Old Mar 25, 2005 | 04:36 AM
Wiking's Avatar
...would anyone know what the problem is or what i should take a look at/replace? thanks
There are lots reasons for that. Dont rush to anything expensive before tests. (= good injectors are 100$ each). Dont buy used...
I would start by general maintenace: plugs, cap, wires, filters, connectrors cleanup, THEN sensor tests.
If all else fails to produce, then check injector resistance, try cleanup (seafoam?) and as last resort swap.
But before all that, go through all pages and figure whattodo. Go through ALL pages, pays!
http://www.cardomain.com/memberpage/748507/1
Old Mar 25, 2005 | 08:53 AM
dantegl's Avatar
maybe you just need a tune up, spark plugs, wires, fuel filter, and possibly an air filter... just a thought...
Old Mar 25, 2005 | 08:54 AM
dantegl's Avatar
ooopps sorry i didnt read wikings earlier post...
Old Mar 25, 2005 | 12:20 PM
Wiking's Avatar
T here is never too much info ...so dont worry, better be happy happy than sorry.
MAXSE5SPD
Sep 17, 2022 04:00 AM
captchaos
Mar 15, 2016 12:18 PM
6spd4dsc
Mar 4, 2016 05:19 PM
jfl330
Sep 4, 2015 01:44 PM
TheMafia
Sep 4, 2015 08:26 AM
