maxima guague pod
Old Feb 25, 2004 | 08:24 PM
icepick's Avatar
maxima guague pod
http://www.gaugepods.com/nissan.html
has them 44.99
also on the air / fuel guage does that coem with a sender or does it hook up to the o2 sensor
thanks
Old Feb 25, 2004 | 08:27 PM
subs1000w's Avatar
just hooks up to the O2 sensor
i believe its a white wire but confirm that with someone else
Old Feb 25, 2004 | 08:51 PM
Michael's Avatar
Back in a 3rd Gen.
has them 44.99
thanks
have had one for a month or so now . Got in on the group deal that got these things produced.
nice quality but the upper screw is in the track. I will probably fill the hole and mount it a different way.
Old Feb 25, 2004 | 09:31 PM
boosted3rdgen's Avatar
i need one too.....does the gauge pod in any way affect the track that the seat belt rides on?
Old Feb 25, 2004 | 09:37 PM
mtcookson's Avatar
i actually put mine over the stock pillar cover and it seemed to fit much better than trying to put it on there by itself.
Old Feb 26, 2004 | 04:57 AM
N34JZ's Avatar
Needs non-Maxima Friends
me too, fit much better that way and now i can still snap the whole thing on and off, without un-screwing anything.
Old Feb 26, 2004 | 05:08 PM
mtcookson's Avatar
yeah, i like being able to snap it off as well. makes it much easier and quicker.
Old Feb 26, 2004 | 05:42 PM
dkris42's Avatar
what would be a good thing to put in those holes for a "cough cough" automatic? and what size holes are they?
Old Feb 26, 2004 | 05:46 PM
mtcookson's Avatar
2 1/16 inch (52 mm) i believe
Old Feb 26, 2004 | 05:55 PM
dkris42's Avatar
okay well what do you think that would be good to put in there for an automatic.........
also.. do they make any white face gagues for the pod to match the white in the speedometer
any good sites that have a bunch of these to check out? Im intrested for the look but never really thought about buying it.....so i never looked for them before..
Old Feb 26, 2004 | 06:02 PM
mtcookson's Avatar
i think www.edoperformance.com has a quite a few gauges. unless you have lots of mods or something not really much else to have a gauge for. things i could think of would be oil pressure, voltage, might be some auto tranny oil temperature gauges out there but i'm not sure, a/f, egr. if you aren't planning on modding much i would personally get oil pressure (since there's just the idiot light on there), possibly the voltage meter (since there's none as well), and the tranny temp gauge if one is made.
Old Feb 26, 2004 | 06:03 PM
MrGone's Avatar
Check out the Autometer Phantom series, they match stock the best.
Auto, you could go with trans temp, oil pressure, volts, oil temp, coolant temp, air/fuel. Really it doesn't make too much of a difference, but if I was auto I'd look into the tranny temp just incase.
I hate to say it, but search for the air fuel hook up there was a thread a month or so ago where we outlined the whole thing. Maybe we can add it to the FAQ's. The guage piggybacks the stock O2 sensor, but you can buy one from Autometer if you want (or if the car doesn't have one..... mainly for older cars).
Also try to buy from the guys who have extra's. Some people bought spares so that the minimum requirement would be met and they could be made. Matt93SE probably has his spare one still, and if he sold it, KLoWnPr109 is selling his too.
Old Feb 26, 2004 | 06:08 PM
dkris42's Avatar
alright thank you very much for the help......i just hope i'll be able to wire them all up.......plus i have the tan interior so I would have to redo the color also....umm so if you put directly on the pillar it will screw in right?
man gauges arnt cheap
Old Feb 26, 2004 | 06:56 PM
N34JZ's Avatar
www.gaugeman.com
Old Feb 27, 2004 | 01:44 PM
dkris42's Avatar
hum alright thanks.....does anyone know what kind of cloth is on our pillars so i can get some and wrap my gauge in it to make it look stock there.
Old Feb 27, 2004 | 11:07 PM
Kevincleff's Avatar
Hey guys. Long time no talk. Sorry about the way the top screw runs in the track but I was pretty much told there would be no fitment issues with and when I tried on my max it fit fine so I dont know why they put that top screw where they put it. I hope everyone is happy with them. If the top screw is that much of a problem maybe I should call them back up and have them fix but let me know what you guys want to do about it. I'm still waiting for someone to get some gauges in there and get a good picture up! Well keep up the modding fellas and remember if you guys are in the orlando area shoot me an email at kevincleff@aol.com
Old Feb 27, 2004 | 11:57 PM
MrGone's Avatar
Matt
Old Feb 28, 2004 | 08:42 PM
Aaron92SE's Avatar
NWP Engineering.com
Air/Fuel gauges that taps into your stock narrowband o2 sensor signal DO ABSOLUTELY NOTHING. I call it a really cool ricer light show. A voltmeter tapped into the signal can show more than an AF gauge.
If you are really interested in your AF ratio, then you can go the cheap way out and get an EGT gauge or do what I did for my ECU tuning project:
http://www.plxdevices.com/onlinestore_domestic.htm
That's right. Your very own wideband o2 sensor that tells you what your exact AF ratio is at any given time on a digital display. Much cheaper than spending hours on the dyno. With my tuning software, I am able to datalog the figures, which is the entire reason I got it.
If you have an automatic, then tranny temp is a very nice thing to have, especially in the summer time. 90% of tranny failures are due to heat.
I highly recommend a coolant temp gauge. Your motor's performance is highly dependant on the temp. Take it from me, a serious bracket racer.
Oil pressure gauge is always nice to have. Just to keep an eye on things. But I've never really used mine since my oil pressure is always pretty good.
When I had battery/altenator problems, I REALLY wish I had a volt gauge. Those can come in handy too believe it or not.
Old Feb 28, 2004 | 09:42 PM
mtcookson's Avatar
holy crap! i didn't know you could get wide band sensors for that cheap. i may pick one up very soon. can a normal a/f gauge tap into the wide band sensor and read them correctly or do i need to buy a special gauge?
Old Feb 29, 2004 | 01:31 AM
Aaron92SE's Avatar
NWP Engineering.com
A normal AF gauge won't be able to give you accurate readings if you tap into the wideband signal. This kit comes with a digital display. I believe there are companies out there that make an analog wideband o2 sensor gauge. But I prefer digital since you can easily tell the difference between 12.8 and 12.7:1 AFR.
Old Feb 29, 2004 | 01:59 AM
MrGone's Avatar
One thing that is nice about the Autometer A/F is you know when its going into closed loop and such, just kind of fun.
Old Feb 29, 2004 | 02:13 PM
mtcookson's Avatar
so the digital gauge on that website will actually show the afr or just a voltage? looks like it shows afr from the picture but it so small i can't really tell.
Old Feb 29, 2004 | 02:38 PM
Aaron92SE's Avatar
NWP Engineering.com
It recieves a particular voltage from the wideband o2 sensor. And since the display is also a "controller", then it converts that voltage to a number you can read. So the numbers you'll see are something like this, "12.78", "13.51", etc. So it's the actual AFR. Isn't that awesome? It makes this SO much better than paying those outrageous dyno prices.
And hopefully soon, I will have a new feature in this Zemulator that allows me to use my front wheel speed sensor to do street dyno runs. I know it works for the rear wheel speed sensor on z32s, I just hope it works on my car. It should.
Old Feb 29, 2004 | 06:49 PM
mtcookson's Avatar
that's awesome. i'm going to try picking one of those up real soon. thanks for posting that link!
Old Mar 1, 2004 | 02:16 PM
Aaron92SE's Avatar
NWP Engineering.com
No problem. You REALLY need one of those. It's not too expensive and you'll know exactly what your AFR is at all times. I haven't figured out a place to mount the display. But right now, I just crammed it inbetween my Ebrake and passenger seat.
Old Mar 1, 2004 | 02:23 PM
mtcookson's Avatar
it looks pretty small so i'd probably sit it on the top of the gauge cluster or on top of the steering wheel so i can quickly look at it if need be.
Old Mar 1, 2004 | 03:21 PM
Aaron92SE's Avatar
NWP Engineering.com
I'd have to say it's 2.5" wide, 7/8" tall, and 4" deep. I tried to sit it above my clock on my dash, but I can't get it to stay with even the strongest velcro I could find. The velcro held of course, but the sticky part of it wont' stick to the dash. I washed all the armor all clean too.
I'm sure you could stick it on the steering wheel somehow if you come up with a way to make it stay.
Old Mar 1, 2004 | 08:24 PM
mtcookson's Avatar
duck tape!
i'll see what i can do to get it to stay.
halfpol
Oct 17, 2022 12:16 PM
Goffery2uned
Aug 21, 2015 09:50 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
