Anyone in STL that can help me replace my window regulator
Old Feb 26, 2004 | 04:52 AM
maxima76's Avatar
Hey guys wanted to know if someone could help me with this problem I have read a lot on this site and it seems like the regulator may be what's wrong but I don't know....My driver side window won't even come down when I push the button...to get it to comes down I have to push the other button that makes the window go all the way down a couple of times..but then it goes right back up.....My passager side window goes down but hesitates going back up sometime.
I would like to do it myself but scared I will screw up something if anyone lives near me I can pay you for your time.
Old Feb 26, 2004 | 06:07 AM
aeubank's Avatar
Hey dude. Replacing the window regulator is a very easy job. Relax. I live in NC and woyuld be willing to help you through emails, etc. Replacing the panel is a simple matter of removing all of the screws in the door panel then removing the assembly that holds the window in place.. Come to think of it you're problem might not be the regulator. It could be the motor itself..
On a scale of 1 to 10 I would rate this job a 3. In comparison, I would rate changing the oil as a 2.
You can do it!!
Old Feb 26, 2004 | 06:15 AM
internetautomar's Avatar
mod or sell?
Problem doesn't sound like a reg to me.
Old Feb 26, 2004 | 08:54 AM
joe3931's Avatar
You can find detailed instructions on How TO section in following link.
http://www.geocities.com/craigbrace/ (Very good info)
Before replacing you may want to lubricate the Window rails. Use a silicone based lubricant (or make sure it is labled safe for use in rubber ;plastic or paint). Dont use WD40.
You may also want to make sure the Switch contacts are not bad.
Old Feb 26, 2004 | 10:18 AM
subs1000w's Avatar
that problem definitly dont sound like a regulator. it sounds like the switch
and i live in st louis and would be glad to help so let me know
Old Feb 26, 2004 | 02:17 PM
usmanasif's Avatar
Yup...THIS IS NOT A REGULATOR! Lets not get this guy on the wrong track here, guys.
If it was, you would not have any window movement whatsoever. In fact, the window would have rolled down and stayed there if the reg cable had snapped.
Matt93SE
May 24, 2019 02:58 PM
Cotozic
Jun 28, 2017 08:01 PM
vingodine
45
May 21, 2016 12:46 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
Superbform
Aug 11, 2015 08:10 PM
