failed attempt at vtc rewire
Old Mar 1, 2004 | 03:17 AM
Grisadiche's Avatar
Last night i did the vtc rewire on my max. Everything went to plan, and i went by the write up on craig's page. I took the car out for a spin after i was done, and the vtc's were still making noise. In the write up, he uses the solenoid nearer the front of the engine, and i used the one further away, thats the only thing i can think of that i did differently, or is it something else?
Old Mar 1, 2004 | 03:27 AM
MrGone's Avatar
you used the yellow wire right?
if you lug the engine, does the clicking go away?
Old Mar 1, 2004 | 04:40 AM
Michael's Avatar
Back in a 3rd Gen.
if you used the yellow wire then you just dont have a good enough ground probably.
Although there have been some reports that some VTCs were so bad that the clicking remained or came back after the re-wire.
Old Mar 1, 2004 | 06:13 AM
subs1000w's Avatar
yup my old engine was like that
Old Mar 1, 2004 | 06:41 AM
Cliff Clavin's Avatar
Way out West
I'll bet mine would be like that if I were to try it.
(but I still want to try it, MrGone!) hahaha
chris
Old Mar 1, 2004 | 07:54 AM
midoriryu's Avatar
used VTCs for $300 (for both) or $500 for rebuilds : )
Old Mar 1, 2004 | 08:07 AM
Grisadiche's Avatar
i'll check the ground, maybe see if i can make it a little bit better, and yes i did use the yellow wire.
thanks, i'll check it out
Old Mar 1, 2004 | 08:59 AM
subs1000w's Avatar
i just used a ring terminal and grounded it the the intake manifold bolt where the injestors are grounded
Old Mar 2, 2004 | 06:42 AM
CamryKilla's Avatar
whats the best way to ground em so the ticking doesnt come back...or is there only one way?
Old Mar 2, 2004 | 08:04 AM
Grisadiche's Avatar
after checking the ground, and finding that it was good, i decided i'd also check the power of the yellow wire, i removed the ground and there was no power through the yellow wire when the car was turned to on, i'm pretty sure it says in the write up that it is supposed to have power, could that be cause of the failure??
Old Mar 2, 2004 | 11:44 AM
Damonb's Avatar
The other wire would have power (positive) when key is on, if the yellow wire had a B+ and you hooked up a ground wire to that, it would blow a fuse man.
Old Mar 9, 2004 | 12:37 PM
Nmax92's Avatar
Here is a mystery for you guys to solve. I grounded my vtc's and then went to start the car, but the car won't start. Not a sound from the engine. When I disconnected the ground it started up. Also when the car first starts up, there is no noise until it warms up. solve this one. HA
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
dshinn
Sep 26, 2015 08:07 PM
Pied
Sep 26, 2015 03:29 PM
Noela
Sep 26, 2015 08:22 AM
