VE30DE and VG30DE
Old Mar 2, 2004 | 09:20 AM
evilvamp7's Avatar
VE30DE and VG30DE
i wona know if i can change the VE30DE motor block to a VG30DE block if not at least the piston and rod pl let me know if this can be done
Old Mar 2, 2004 | 09:48 AM
Jeff92se's Avatar
I'm needing a caw
Parts fit into the block. Probably. Why would be a good question here. Both are iron blocks.
Or are you assuming the VG version is somehow stronger?
Old Mar 2, 2004 | 10:07 AM
evilvamp7's Avatar
i am talking about the 300z motor VG30DE turbo i wona have that piston and rod and if i can put it on the VE30DE
Old Mar 2, 2004 | 10:31 AM
mtcookson's Avatar
the vg30e(t), ve30de, and vg30de(tt) all have the same bore and stroke so the rods and pistons of the vg30de(tt) should theoretically fit. what's nice about the tt rods (and crank) is they are forged and i hear are supposed to handle about 600 hp in stock form. the pistons are cast however so they probably don't handle as much.
the blocks are most likely not interchangeable though.
Old Mar 2, 2004 | 10:35 AM
Pervis Anathema's Avatar
Why don't you just drop in the VG30DETT? It bolts right up.
Old Mar 2, 2004 | 11:05 AM
evilvamp7's Avatar
so if i take the piston and rod ,crank and put it in the my VE30DE how much HP it will handle with the turbo too
Old Mar 2, 2004 | 11:23 AM
Julio's Avatar
First off, the vg30de or the vg30dett do not bolt right up, they dont fit to begin with.
Rods and pistons are a direct swap though, both myself and MadMax024 have done it. Are cars are running great to this day. Besides, you would want to keep the stock rods because they have oil squirters in them, and the vg30de ones do not, theirs are on the block themselves. They are both forged and same size, so they can probably take the same power. Seeing as how you are asking this question, i would worry about power issues yet.
Old Mar 2, 2004 | 11:24 AM
MrGone's Avatar
I dont know if you could use the crank, I'm doubtful because the VG has a timing belt, we have a timing chain.
Yes VG30DE(and TT) Rods and Pistons will fit in a VE. Infact you can use VE rods and VG30DE pistons or anything, the VE and VG30DE pistons and rods have all the same specs.
Now if you want to put VG30DE parts in your VG30E you need to use both VG30DE Rods and pistons. You cannot put the VG30DE piston on a VG30E rod.
Old Mar 2, 2004 | 11:59 AM
evilvamp7's Avatar
did u change the rods and piston and can u feel the different what motor did u get the rods and piston is it VG30DETT or VG30DE
Old Mar 2, 2004 | 02:43 PM
Matt93SE's Avatar
STFU n00b!
a couple suggestions..
1. proper English.
2. proper punctuation.
I can barely understand what you're asking on half your questions, and I can't understand it at all on the other half.
Old Mar 2, 2004 | 03:30 PM
subs1000w's Avatar
im pretty sure they got the rods/pistons out of a non turbo VG30DE because the TT version has lower compression so the pistons are proboly different unless the combustions chambers are bigger
Old Mar 2, 2004 | 04:36 PM
MaDMaX024's Avatar
well actually you're only half right.
my pistons are from a DE, julio's are from a DETT..so now there are 2 full points of compression that separate us. both motors run excellent..neither of us used the rods because of the oil squirters on the VE rods.
Old Mar 2, 2004 | 04:39 PM
Jeff92se's Avatar
I'm needing a caw
How is your car running now? I thought I read you were having problems of some sort? And julio is running the lower compression TT pistons but running it na for now?
Old Mar 2, 2004 | 06:00 PM
mtcookson's Avatar
don't the dett rods have the squirters?
Old Mar 2, 2004 | 06:28 PM
maximase86's Avatar
I love lamp.
The rods don't themselves, but the have squirters at the base of the cylinders.....
Lucky for you guys, my buddy Brian (schuss) is doing a complete motor rebuild and swap on his 91 Z32 TT.
You can see the squirters at the base of each cylinder V pair:
Shot of the rod, but no, they do not have squirters:
All these pics belong to schuss.
S
Old Mar 2, 2004 | 08:56 PM
Julio's Avatar
And julio is running the lower compression TT pistons but running it na for now?[/QUOTE]
For now I am
Old Mar 2, 2004 | 09:54 PM
MaDMaX024's Avatar
i'm having all kinds of stupid problems, but its all sensor related..the motor is rock solid sometimes, its just everything around it seems to be falling apart..whatever, i blocked my EGR and its running a ton better...still a few loose ends i need to tie up..for now i'm all over the suspension (read sig), but its proving to be a bit more costly than i thought. its getting warmer out so i'm more motivated to work on my car so things will get done alot faster along with more new stuff coming out (read: lower intake spacers in addition to TB and upper intake spacers i have currently...shameless plug, $65 shipped for lower, $25 shipped for TB...PM/email/IM if you're interested)
Old Mar 2, 2004 | 10:54 PM
chrgdRapa's Avatar
you will need a real wheel drive to do the swap, then most likely a new suspension. its a lot of money but
if you can afford it..
Old Mar 2, 2004 | 11:00 PM
Matt93SE's Avatar
STFU n00b!
WTF?!?! yeaaaaah.
Old Mar 2, 2004 | 11:15 PM
chrgdRapa's Avatar
okay. i thought he meant the whole engine swap. i got so damn confused with 5 people i know making swaps with SR20's and 350zx's, but they all got rear wheel drives.
Old Mar 2, 2004 | 11:23 PM
Matt93SE's Avatar
STFU n00b!
what's a 350ZX?
Old Mar 3, 2004 | 06:18 AM
Kyle's Avatar
problably he means 350z, basically the same thing.
Old Mar 3, 2004 | 06:59 AM
Matt93SE's Avatar
STFU n00b!
how are they basically the same thing when one doesn't exist?
Old Mar 4, 2004 | 03:00 AM
nismobaron's Avatar
It might do in other markets - esp Japan. After all the US 300Z is known as 300ZX in non-US markets, the 240/260/280/300Z was also known as Fairlady in Japan (don't ask...), the NX2000 is known as 100NX in UK, NX Coupe in Japan, Stanza is Bluebird in UK / OZ / NZ / Japan, US Sentra is either Pulsar or Sunny in NZ, OZ, UK, Japan etc. You kinda get the point...
Old Mar 4, 2004 | 04:19 AM
sinister's Avatar
ok now this is my question does the whole vg30de engine fit in the 89 maxima???
Old Mar 4, 2004 | 04:36 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
yes it does
Old Mar 4, 2004 | 06:41 AM
Sawby4president's Avatar
wouldn't that kinda horsepower slaughter a maxima transmission? especially an auto?
Old Mar 4, 2004 | 06:51 AM
subs1000w's Avatar
not if you spend the 4000$ for a performance rebiuld
Old Mar 4, 2004 | 07:18 AM
internetautomar's Avatar
mod or sell?
NO!
:10char:
Old Mar 4, 2004 | 11:37 AM
sinister's Avatar
damn i was looking foward to that
Old Mar 4, 2004 | 07:09 PM
mod or sell?
Yes it will.
But not in the engine bay fully assembled with transmission
Matt93SE
May 24, 2019 02:58 PM
Dummy
18
Jul 29, 2002 01:39 PM
hooptey
Jun 8, 2002 11:39 PM
Nismo87SE
Jan 14, 2002 02:56 AM
Nismo87SE
Sep 14, 2000 11:41 AM
