Quick help!
Quick help!
Hey, my car started running like crap, check engine light on.
the code i got from diag mode 3 is 5 red, 1 green, meaning code 51.
Can anyone tell me what that code means?
Thanks a crapload in advance,
Andy
Andy
do you have a california model? looks like that error code is on the cali models and not the fed spec models.
looks like what the fsm is saying is there is short in the wiring or even in the injector. might check the plugs on the injectors and see if they are corroded. if so, you'll want to clean those up.
once you do that, you can reset your ecu by going to mode 4 of the diagnostics selection and then turn the key back off. this will reset the ecu.
drive around and see if your problem still persists and check to see if the code turns back on. good luck man!
Mar 12, 2020 12:06 AM
NewMax03
Oct 7, 2015 08:27 AM
