Please read, need your help
Old Mar 10, 2004 | 08:19 AM
Maxdude's Avatar
Help please.
It’s about 3 weeks now that my RPM has been acting weird sometimes mostly in the mornings but also while in Park or Drive. For instance it’ll drop a little from its normal position and then will go back to normal again and I feel a kick while it does this. This is not a constant issue, but it may do this once then after a few seconds again and sometimes after a minute or two. I’ve also noticed my car doesn’t have the power it used to.
So far I’ve done the following trying to correct the problem and have noticed no difference:
Got new NGK V-power plugs
Got new ign wires
NTK o2 sensor on it’s way
I had Bosch platinums before and as far as I remember this problem started right after I changed them to the NGK ones. Not sure though. Could this be a problem? Maybe the plugs I changed to are bad or not accepted by my Max?
Any help would certainly be appreciated, since this is piecing me off and
Old Mar 10, 2004 | 10:15 AM
eric93SE's Avatar
Originally Posted by Maxdude
Help please.
Got new ign wires
Hey I just bought a set of NGK V-power plugs. But I'd kinda doubt thats the problem. Maybe you should check all the ignition wires to see if they are connecting well.
Old Mar 10, 2004 | 11:19 AM
Maxdude's Avatar
I have but problem persists. There is one vacume hose that's been loose for about the same time this problem arose and I'm hoping that'll solve the problem. It's the little hose which goes from near the TB to the upper part of the black canister under the battery/fuses. I accidently broke off the little plastic tube the hose fits on while changing the hose and haven't had the time to reconnect. I gotta think of how though.
Old Mar 10, 2004 | 11:59 AM
Seyath's Avatar
Have you checked your tranny fluid? Now wishing bad luck but that happened to me and now my car is sitting waiting for a new transmission...
Old Mar 10, 2004 | 12:00 PM
Maxdude's Avatar
Yep, the fluid is good.
Old Mar 10, 2004 | 12:07 PM
Seyath's Avatar
How many miles on your Auto?
Old Mar 10, 2004 | 12:29 PM
Maxdude's Avatar
it has 162,000
Seyath's Avatar
Cross your fingers and hope it's not dying...
mclasser
22
Nov 12, 2020 01:58 PM
chisam14
Nov 6, 2018 08:56 PM
mkaresh
Mar 12, 2018 06:48 PM
maxinout93
Oct 31, 2015 02:04 AM
