Timing Belt & Water pump, 93 GXE
Old Mar 10, 2004 | 01:57 PM
mehul's Avatar
Does anyone know of a reasonable and good place to get the Timing Belt and waterpump replaced? Just called a dealer who said $750 plus tax!
Thanks.
Old Mar 10, 2004 | 02:04 PM
internetautomar's Avatar
mod or sell?
Parts or Parts and labor?
Old Mar 10, 2004 | 02:07 PM
Seyath's Avatar
That better be with Labor included. Even then I wouldn't shell out $750 to replace water pump and Timing Belt. I would just replace them myself. Not that hard really. Just buy the parts yourself, two jackstands and a Chilton Manual. You should be able to replace them easily with basic mechaninc skills.
Old Mar 10, 2004 | 09:31 PM
MaximamixaM's Avatar
I'll need to have the same service down in the near future. I'm going to have a local garage that does import service do it. I'll have them replace the waterpump and timing belt. Does anybody know if anything else should be changed-like timing belt tensioners, sensors, or hoses while doing this 60K service?
Old Mar 10, 2004 | 10:02 PM
torontomaxima's Avatar
Well when I had mine done, my mechanic recommended changing some of the belts, and sealant on some part near the water pump/timing belt.
Old Mar 11, 2004 | 05:57 AM
mehul's Avatar
The quote was for parts + labor. How much are the original nissan parts?
Old Mar 11, 2004 | 07:09 AM
Just call a dealer - I paid $650 CDN for parts + labour to have my water pump/timingbelt/seals replaced. Mind you it was aftermarket parts, and under the table from my mechanic.
Old Mar 11, 2004 | 08:15 AM
mehul's Avatar
I have a quote from another dealer now, for $585+ tax, incl. timing belt, water pump, all drive belts, cam and crank seals, including parts and labor. Yet another dealer quoted $470 for timing belt and waterpump including parts and labor. Do the seals and drive belts HAVE to be replaced at 120K?
Old Mar 11, 2004 | 09:36 AM
tucker's Avatar
Got mine in a dealer right now. It'll be done tonight. $550 for the timing belt, water pump and accessory belts. The seals they're talking about are the cam and crank seals. My dealer wanted $20/each and 1/2 hr. labor ($40) each total $180. I opted not to have seals done. I only have 95K on the car. As far as doing it yourself; there's a guy who posts alot with a beautiful black SE. He didn't line up his marks just right and lunched his engine.
Old Mar 11, 2004 | 09:47 AM
mehul's Avatar
So you think I should get the seals done? I have a quote for 585+tax including seals, all drive belts, timing belt, and water pump. Another quote is 470+tax for timing belt and water pump.
Old Mar 11, 2004 | 09:58 AM
tucker's Avatar
Are these prices from a dealer? If so I'd go with the seals too; that's a good price. If your not using a dealer, be sure they use a Nissan belt. There have been bunches of threads about after market belts being cheap
Old Mar 11, 2004 | 10:42 AM
mehul's Avatar
Yup...Its from a dealer. I thought it was a good price too, but dont want to get the drive belts and seals done spending $115 extra, unless I HAVE to! Not that I'm cheap, but I've had to spend almost 1200 bucks on the max in the last 2 months!
Old Mar 11, 2004 | 10:54 AM
Jeff92se's Avatar
I'm needing a caw
WHAT drive belts? Accessory belts? Might as well get it done. Seals? Cam seals? $115 for all that isn't that bad. Takes some time to remove the cam sprockets and pry off the seals.
Old Mar 11, 2004 | 11:23 AM
Yeah get it all done now since it's being worked on anyways.
Old Mar 11, 2004 | 05:33 PM
bvtran's Avatar
94c Big Max
Thanks.
LOL. You could probably even pay WAY LESS by flying Mr. Matt Blemn to MA + his hotel + transportation + his works on your car ($35/hr is is quote) + maybe along with some female entertainments toooooo.
Old Mar 11, 2004 | 05:36 PM
Seyath's Avatar
I'll do the work for him he he flies me and my girlies....
Ray229Harris
Sep 16, 2015 08:16 PM
Alberto10mg
Aug 25, 2015 12:54 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
