Oil puddling around spark plug on cylinder 3
Old Mar 15, 2004 | 03:22 PM
AscendantMax's Avatar
Spent an hour today cleaning up the engine bay a bit. Noticed the area around cylinder 3 was a bit moist. Pulled the spark plug wire off and the tip had a ring of oil on it. I looked down the hole, and there were oil puddling around the sparkplug. The sparkplug is not loose or anything. Where else can the oil come from? The other 5 are dry. Thanks in advance
Old Mar 15, 2004 | 03:38 PM
mtcookson's Avatar
can you see and residue where the oil was dripping or anything? only thing i can think of is the valve cover is leaking a little bit. you can tighten those screws on top a little and see if that helps.
Old Mar 15, 2004 | 04:45 PM
there was no residue in the oil, it was rather clean. but i'll tighten up the valve cover screws around that area, to see if that'll help. thanks for the reply.
Old Mar 15, 2004 | 06:27 PM
Matt93SE's Avatar
STFU n00b!
yup.. 99% of the time, it's the valve covers.. no real way oil can leak in there like that.
Gingerheadman
Oct 1, 2015 05:11 PM
msellas
Sep 23, 2015 09:16 PM
homewrecker
Sep 23, 2015 03:41 AM
JoshG
51
Sep 21, 2015 10:41 PM
