spark plug gap
Old Mar 29, 2004 | 04:04 PM
max723's Avatar
spark plug gap
what do you gap the plugs to on a ve engine. also what would happen if you over torqued them a little.
Old Mar 29, 2004 | 04:12 PM
MrGone's Avatar
.39-.44
see sig for torque
Old Mar 29, 2004 | 05:10 PM
jwmaxse's Avatar
If you overtorqued them a bit too much, it wouldn't really hurt anything. If you overtorqued them WAY too much, you could probably strip the threads out and that would cost some major $$$ to fix.
Old Mar 29, 2004 | 05:54 PM
eric93SE's Avatar
Also if you overtorque them it is possible to crack the ceramic insulator. But I kinda doubt you really overtorqued them. I've been using a torque wrench on mine when installing them, and its WAY tighter than what I used to do. The torque spec is around 12 ft-lbs. Its actually important that the plugs are torqued porperly, a loose plug will not dissapate heat they way it was designed to, and if too tight (well you already know after the last responses you got).
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
