Engine has the Shakes
Old Mar 30, 2004 | 02:01 PM
ickmak's Avatar
Well I have a 89 4 door Maxima (duh) se. I let my friend borrow my car because he is looking to get one. Anyway, He's driving down the highway and starts to exit off and then the engine starts to shake then dies. He lets it sit a little bit then starts it back up stilling shaking. He shuts it off waits awhile then tries again, runs fine. He brought it back to me and told me what happen now it sits awaiting the mechanic. What do you guys think? Beside get a 92 se 5 speed.
Old Mar 30, 2004 | 02:08 PM
lophix's Avatar
hmm sounds weird...like one of those one-off occurrences that sometimes happens...was it low on gas, is it a 5speed? I figure since it seems to be fine now, you might as well wait for it to happen under your watch that way you can better observe the symptoms and all that.
Old Mar 30, 2004 | 02:11 PM
ickmak's Avatar
Half a tank, yes its a 5 speed eveything is stock. Nothing leaking, could it just need a tune up.
Old Mar 30, 2004 | 02:15 PM
lophix's Avatar
might be...and he knows how to drive a manual pretty well i assume? remember when last you changed the plugs/wires/ distributor cap/rotor etc.
Old Mar 30, 2004 | 02:20 PM
specialmax's Avatar
I had the same problem with a different car- turned out to be a bad plug wire/bad connection with the spark plug. Check the distributor cap, rotor button, plug wires, and battery terminals for cracks, wear, bad connection, etc. Pull out a spark plug and see if it is gummed up.
If the engine died, it is possibly because it was not getting fuel, so check/change your fuel filter. You also might want to check your fuse relay box to see if the fuse to the fuel pump is in good shape. It sounds like an electrical problem to me.
ickmak's Avatar
Thats funny about the 5 speed, yeah he knows. Really don't know cause i just bought the car a couple of months ago. Haven't had time to do all of that stuff guess i'll start there
JoshG
51
Sep 21, 2015 10:41 PM
jchronis2552
Sep 21, 2015 05:52 AM
Socalstillen
Sep 20, 2015 11:46 PM
Bonka
Sep 14, 2015 11:18 PM
