headlight problem, need help quick!
Old Mar 31, 2004 | 09:20 AM
matt92gxe's Avatar
hey guys, it's been forever since i was on here! i figured you all might be able to give me some information. my driver's side headlight will not work. it is not the bulb b/c i already replaced it. but, it will work on brights. i have fairly new wiring harnesses so i know that is not the problem, and i changed out all the fuses. also, sometimes my brights don't work on the 1st try, i gotta flash them 2 or 3 times to make them work. i just want to get everything working right again, and never mess with those things again! i had those nokya bulbs like 2 or 3 years ago, and they haven't been right since. been running stock bulbs for about a year now and i can't understand why i'm having these problems? please, someone tell me what to do!
Old Mar 31, 2004 | 09:27 AM
MaximamixaM's Avatar
Are you stock or do you have any other mods? I've heard of a burned out light switch/stalk on the steering column causing one headlight to not work-can't remember if it usually wipes out hi and low on one side, or just affects one function. I think there was a post a few days ago sort of similiar, so try and scroll back a few days. Of course, have you switched bulbs to make sure it isn't a bulb problem. What problems did the nokya bulbs cause?
Old Mar 31, 2004 | 09:32 AM
matt92gxe's Avatar
should have said that when i had the nokya bulbs, i also put in an apc rewire kit, but i don't see how that would have gone bad with stock bulbs in it?
Old Mar 31, 2004 | 12:26 PM
«§»Craig B«§»'s Avatar
sounds to me like it's the headlight stalk on the steering column
I've heard of these going bad on several 3rd gens before.
If you happen to live near someone in Lexington/UK area who you could borrow a stalk from, that'd be an easy way to test it (JAY)
Old Mar 31, 2004 | 01:25 PM
matt92gxe's Avatar
thanks a lot craig! i'll get with jay as soon as i can, i live fairly close to him and have met him several times. he told me you are the man when it comes to stuff like this!
Old Mar 31, 2004 | 01:38 PM
aw89maxSE's Avatar
You think that could be my problem too.....
Here's what I posted a few days ago....
Originally Posted by aw89maxSE
I went to arizona and left my car at my girlfriends house for a week or so and when I started it up and turned the lights on, the passenger side light came on normally for just a split second and then went out. I tried the HI beam and it wouldn't go on either. I am thinking a possible blown fuse or something with the relays, but I really don't know. Help me out guys, I've been pulled over too many times for only one headlight
I checked the fuses and what I heard from the thread was that it wasn't the relay. Maybe a rewire is in order, but I don't know.
MaxLife17
Jun 27, 2019 01:37 PM
dvcamp
Sep 18, 2015 10:17 AM
LtLeary
Sep 14, 2015 12:33 PM
MaxLife17
Sep 8, 2015 02:36 PM
trungg86
Sep 4, 2015 04:58 AM
