Auto question for 92-94 SE's
Old Apr 4, 2004 | 09:30 PM
5 ltr. beater's Avatar
what mods "cure" the sluggish 1st gear start. Apparently every auto maxima that i've driven has this problem. From a roll and in high speed, there are fasirly fast; but from a stop, you wonder where did all the power go.
Old Apr 5, 2004 | 07:10 AM
Matt93SE's Avatar
STFU n00b!
more power... higher stall TC, other bolt-ons...
the gearing is too tall in the autos, and there'w not much you can do about it but add power to overcome it.
Old Apr 5, 2004 | 07:23 AM
subs1000w's Avatar
5spd swap or nitrous is the only way
Old Apr 5, 2004 | 09:40 AM
Mizeree_X's Avatar
Getting back to his roots
An underdrive pulley is usually a cheap way to get you revving quicker. Aaron92SE said it shaved 0.2 from his 1/4 mile time, and for the VE engine they are only $100 + cost of belts.
Old Apr 5, 2004 | 10:10 AM
dmontzsta's Avatar
Ford Only.
Talk to Aaron.
But no matter what you do, it is still an auto. On the street a 5 speed can be RIGHT with you off the line and DESTROY you up top.
Old Apr 5, 2004 | 03:11 PM
Aaron92SE's Avatar
NWP Engineering.com
As people already said, you just need more power. That's all. As fast as I am, I still have a sluggish low end on the street, with my street tires and full interior.
But, I recommend to get these things first:
Cold Air Intake
Ypipe
UDP
Slap all those mods on at the same time and you'll have a nice little smile when you experience the wrath of your top end power. But low end will still be sluggish. So I went more extreme by doing this:
Smaller Tires (JUST for the track) for better gearing. It makes the gears much shorter.
And a high stall torque converter will shorten that sluggish lag in low end.
With those mods, you will be easily cutting 2.20s at the drag strip and will beat a lot of cars out of the hole with perfect traction everytime. VLSD, automatic, small tires, TC are awesome things.
The only way to be faster than that is get 22" MT slicks and spraying a 50 shot out of the hole for those 1.8 60's.
Old Apr 5, 2004 | 09:09 PM
thanx for the help guys. I havent owned a maxima in a long time and i need to learn the basics.
2kmaximel
Nov 29, 2015 01:51 AM
bumpypickle
Sep 20, 2015 08:22 AM
pears
Sep 18, 2015 05:25 AM
