Engine Diagnostic
Old Apr 6, 2004 | 07:41 AM
MAXI's Avatar
Engine Diagnostic
1989 SE with a VG30.
Can someone guide me on how to do an engine diagnostic????
i'm looking at the Haynes book and its no help.
Old Apr 6, 2004 | 08:08 AM
subs1000w's Avatar
well you need to tell us what the engines doing or not doing before we can tell you how to diagnose it
Old Apr 6, 2004 | 08:25 AM
MAXI's Avatar
"Check Engine" is on but the car is running fine though.
Btw...the procedure i was thinking is via the ecu.
Old Apr 6, 2004 | 09:57 AM
specialmax's Avatar
Go to the Haynes Manual section on Emissions, and at the back of it, it should show you how to read your ECU. If not, go to AutoZone and get the Code Scanner that is available for Nissan, Honda, and Toyota.
When the check engine light is on but the car is running fine, it is usually an emissions thing going on. Check your PCV valve, your EGR valve, and your O2 sensor. Those are the usual culprits.
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
