Taillight Removal?
Old Apr 6, 2004 | 12:08 PM
ghettogeek's Avatar
Taillight Removal?
I was wondering if anyone here has experience removing the taillights. Not to take the cover off and change the bulbs...to take out the whole tailight so I can modify it. It looks like it's stuck in there with some sort of adhesive that I'd have to melt off. Anyone have any ideas/comments? Thanks.
Old Apr 6, 2004 | 01:26 PM
KRMaxima21's Avatar
I took it off last year to put some SE lights on my GXE. It's not hard at all. All you need is a socket wrench with the right socket. I forgot which socket it is but once you take the bolts off then all u have to do is apply a lil force on the back of the light and it'll push right out. There is a black silicon like substance on the light that will come off a lil when you take the light off so I went to Home Depot and bought Silicon 2 and resealed them in case any water tried too seep in. No problems what so ever. Took me about 20 mins to change them out and add silicon. Good luck !!
Old Apr 6, 2004 | 02:23 PM
HTPerformance's Avatar
Mine didnt take very long to get out, but the best way was to unbolt the 3 bolts...i think 8 or 7mm and then have someone push em while you pull the outside of the housing... The sealant is pretty hefty depending on the age of it...
Brian
Old Apr 6, 2004 | 02:45 PM
8ride's Avatar
Just give them a solid pull, they eventually give. That black silicone that seals them is messy stuff, definatly wear gloves if you plan to remove it.
Old Apr 6, 2004 | 04:42 PM
white90se's Avatar
it makes it alot easier if you use a hair dryer or a heat gun...i didnt feel like standing there with a hair dryer so i used 2 of my halogen work lights and mounted them in the trunk facing the back of the taillight...and left the lights on there for about 2 hours...i only did it that long because i fell asleep...they came out really easy after heating up the sealant
Old Apr 7, 2004 | 05:21 AM
ghettogeek's Avatar
Thanks for all your help! I'll try it out and let everyone know how it goes. Maybe even take some pics after I modify it!
Old Apr 7, 2004 | 06:59 AM
markmaxima's Avatar
tailight
i have to change my tailights, what are the steps i would need to do to take it off thanks
Old Apr 7, 2004 | 07:51 AM
«§»Craig B«§»'s Avatar
check out this thread, it tells most of what you need in the first few posts - http://forums.maxima.org/showthread.php?t=300337
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
