Tranny Cooler!!!
Old Mar 20, 2001 | 04:01 PM
wizard6161's Avatar
I want to install a tranny cooler in my 91 SE. I looked in the shope talk section and the car they were modifying was a 1999. So I would like to know if someone had done this to their cars and what kind of cooler did you use? thank you
Old Mar 20, 2001 | 04:06 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
install is pretty much the same as that...
i used a B&M which i obtained from www.carparts.com
Hayden is another good brand to look into...
Old Mar 20, 2001 | 04:08 PM
wizard6161's Avatar
SO the tranny cooler would go infront of the condenser? behind the grill?
Old Mar 20, 2001 | 04:32 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
yup...i attached mine to the front of the radiator on the driver's side...
Old Mar 20, 2001 | 04:50 PM
wizard6161's Avatar
infront of the radiator? you mean between the radiator and the condenser or what?
Old Mar 21, 2001 | 05:52 AM
brubenstein's Avatar
Mount the cooler betweeen the bumper and the grill. I would also strongly recommend changing the ATF fluid to synthetic when you do this, particularly if you live in a cooler climate. Regular ATF, like motor oil, gets "thick" when it is cold. This thick fluid is hard on the transmission, and with a cooler it will take longer to come up to operating temperature. The synthetic maintains its viscosity to much lower temperatures than regular ATF, and is easier on the trans.
Old Mar 21, 2001 | 09:53 AM
deesel104's Avatar
I used a B&M
I know the B&M cooler installs OK. I just put one on my 93' GXE. It is a pain in the butt to get in the right place....I actually had to rotate my horn about 45 degrees to let the tranny cooler fit. The only place it would install was in front of the condensor on the driver's side....I would assume it would be the same for yours. It also helps to have a helping hand, as I don't think I could have done it myself. I followed the directions given on the following website:
http://grprete.jnet.net/Greg's%20Garage/1999%20Nissan%20Maxima%20SE/1999%20Nissan%20Maxima%20SE%20-%20Xmission%20Cooler.htm
Just to warn you, if you use the B&M ties that are provided, it's a real pain to get the plastic fasteners on the back. You have to put the ties through the condensor and then put the fasteners on behind the condensor, but in front of the radiator. Plan on tearing up your knuckles, but be easy on the radiator fins. Also, if you use the B&M you'll need about 4 ft. of *Transmission Fluid Line*. The only place I found to run the line back to the tranny was through a small hole beside the radiator (driver's side). It is just barely big enough for both lines. Last thing, be sure there's no kinks in the line as they can easily occur when you're running the hoses. Good luck with it!
Old Mar 21, 2001 | 03:15 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
my fault...i meant to say condensor...
tarun900
19
Dec 20, 2021 06:57 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
catalinvint
Sep 16, 2015 07:48 PM
pktaske
Sep 4, 2015 08:40 AM
