Rear BBK interest. Custom brackets, Z31 rear rotors 1" larger
Old Apr 5, 2005 | 08:30 AM
  #161
Jeff92se's Avatar
I'm needing a caw
I never tried them on a stock wheel. Carefull when braking with just the rear bbk. I think Mike had to grind the caliper a bit to get it to fit under the stock 15" wheel.
Old Apr 5, 2005 | 09:15 AM
  #162
internetautomar's Avatar
mod or sell?
yeah someone said that.
the stock wheels just barely hit the caliper bracket at it's highest point.
I'm currently driving like that (and with the one side done)
so it's not too bad, though I probably have a groove in my wheel now where it's rubbing.
I may take pics tonight when the other side is done.
Old Apr 5, 2005 | 11:01 AM
  #163
Brad92SE's Avatar
The calipers will fit easily after about 30 seconds of grinding. On a side note, I havent noticed any problems at all with brake bias, and I have stock front brakes with generic pads (I assume). Those rear calipers suck though, retracting the piston is a *****.
Old Apr 5, 2005 | 11:05 AM
  #164
Jeff92se's Avatar
I'm needing a caw
Brad. You are perfectly set up for the 13" cobra front rotor bbk as you must already know hehe. Upgrade and you won't be dissapointed.
Old Apr 5, 2005 | 11:16 AM
  #165
Brad92SE's Avatar
Well I do have a pair of Z32 caliper lined up, but I dont know if they are the aluminum ones. They are from an earlier TT model. I have to order custom brake lines, right?
Old Apr 5, 2005 | 11:22 AM
  #166
Jeff92se's Avatar
I'm needing a caw
Ask for pics. Alumin ones will have the cooling fins.
http://importnut.net/300zxbrakeswap.htm#MC this is a very nice website for general info. It's for a 240sx but so what? hehe.
Yes you need the custom lines available from. Automax/Derrick/Matt93se etc.. 13" cobra rotors with either the rings (hard to get now) or drilled to the maxima stud hole size. And my brackets to move the caliper out to accomodate the rotor
Old Apr 5, 2005 | 12:05 PM
  #167
Brad92SE's Avatar
Will the cast calipers work also? Or just the aluminum ones.
Old Apr 5, 2005 | 12:10 PM
  #168
Jeff92se's Avatar
I'm needing a caw
As long as they are the 30mm versions, both the steel and alumin are identical in dimension (as far as I know)
Old Apr 5, 2005 | 12:59 PM
  #169
shavedmax's Avatar
my brakes were so bad that the side I did the rotor was stuck to the caliper hmy:
took me about an hour total for the one side. that includes bleeding the caliper (replaced it) and doing the cut on splash shield (?).
the bracket fit perfectly. though I wish we could angle it a bit to give the needed clearance for the stock wheel. I'll probably clearance the bracket tonight.
thats pretty ghetto for someone with so much access to parts
Old Apr 5, 2005 | 01:56 PM
  #170
mod or sell?
and someone who has to replace the trans in the wife's van.
I sold the wheels and tires that I was going to use. because I needed the money for the tranny, also sold my project car.
I only did the half (literally) job because I only had about an hour to do it in.
and that side had no pad left and the pad backing plate was held to the rotor that I had to bang it off. so I did that side to at least get some brakes back.
Old Apr 5, 2005 | 01:57 PM
  #171
Jeff92se's Avatar
I'm needing a caw
Well at least you know he's not gouging us on pricing!
Old Apr 5, 2005 | 05:11 PM
  #172
mod or sell?
second side is done!
the stock SE rim clears it just fine from what I can see (no marks on the rim)
but there is something rubbing, I will be doing more investigation.
I'm less than thrilled with my pedal right now it's probably the cheap calipers I used :-\
  #173
mod or sell?
oh, and I have pics of the dis assembly process and part of the reassembly process (camera died)
Old Apr 6, 2005 | 07:39 AM
  #174
mod or sell?
Pics: http://internetautomart.com/gallery/z31rrbbk
Old Apr 7, 2005 | 08:25 AM
  #175
Lordrandall's Avatar
I left my shields on.
Old Apr 7, 2005 | 08:41 AM
  #176
mod or sell?
mine is still there, but it's trimmed back.
Old Apr 13, 2005 | 10:17 AM
  #177
Jeff92se's Avatar
I'm needing a caw
Another set sold. 2 sets left.
Lordrandal has the rear bbk w/ the following front set. 300z calipers, 300z rotors. (not the 13" Cobra rotors). Reports a nice even braking from the addition of the rear bbk brackets and Z31 rotors.
Old Apr 16, 2005 | 11:32 AM
  #178
Jeff92se's Avatar
I'm needing a caw
Thanks crs max! ONE set left.
Old Apr 25, 2005 | 08:44 AM
  #179
Jeff92se's Avatar
I'm needing a caw
All sets are sold (again). If you want a set, chime in. I don't make these until there is 1-3 people interested.
Old May 10, 2005 | 08:23 AM
  #180
Jeff92se's Avatar
I'm needing a caw
I have someone interested in another set. I can run another batch if I get 2 more confirmed. Here is your chance to get into a rear bbk again.
Old May 11, 2005 | 08:05 PM
  #181
rawmax1's Avatar
i would be interested. But first I plan to change my Drums to discs. By looking at rear suspension. I beleive I need to source both struts/rotors etc cables and lines to make this work. I would appreciate any help
Old May 12, 2005 | 06:16 PM
  #182
shavedmax's Avatar
thats what you gotta do, just go to a junk yard and get it complete from one car. gxe with abs or any year se. most junk yards wont sell you the brake cables(liability issues) but if youre nice enough theyll pull out the e brake for you.
Old May 12, 2005 | 06:41 PM
  #183
rawmax1's Avatar
thanks for the reply. i got a quote today 150 for both sides no cables. Cables are about 58ea my cost.
Old Jul 22, 2005 | 02:27 PM
  #184
Jeff92se's Avatar
I'm needing a caw
I just put in another order for 5 additional rear bbk bracket sets. 2 should be spoken for. That leaves 3 open for sale. Chime in or diaf
Old Jul 23, 2005 | 03:20 AM
  #185
Phatsta's Avatar
Hope one of those spoken for was mine
Old Jul 23, 2005 | 08:47 AM
  #186
James92SE's Avatar
2 VE's are better than one!
I definitely want a set.. can I pay you early so that I make sure I dont miss out on them again somehow?
Old Jul 24, 2005 | 08:23 PM
  #187
mrkanda's Avatar
Taking my Maxima to the Max!
I will also want a set as soon as I can afford them. That should be in a month or so. I'm not sure if any will still be available from this batch then, but hopefull there will be another batch after that.
One question about the front, if you don't mind. I want to go with a BBK for the front as well but would like to switch back to stock rotors for use with stock wheels in the winter. What calipers can I use to go with either Cobra or Z big rotors that will give me the best performance but also be able to fit under a stock wheel once I switch back for the winter? I'm contemplating using a set of I35 17" wheels for stock replacements and could possibly use those for mounting a set of winter tires, and go with a set of G35 18's for summer use, but I'm not sure what kind of spoke clearance I would have with the I35's to use with bigger calipers. I'm just not sure if I can use something bigger and better than stock calipers and maintain swappability with my wheels without having to switch calipers. Whatever advice or direction you can give will be greatly appreciated. Thanks.
-Mrkanda
Old Jul 25, 2005 | 08:02 AM
  #188
Jeff92se's Avatar
I'm needing a caw
I'll probably have a set of rear brackets still.
The ONLY way you will be able to run your stock 15s is to swap the stock rotors and stock calipers back on. G35swill clear everything with no problems as I've run them (and have a set for sale). I35 wheels probably will not work. G35 17s might work though.
Old Aug 26, 2005 | 12:54 PM
  #189
Jeff92se's Avatar
I'm needing a caw
I had 5 new sets made. 1 set is already going to Phasta (eventually!)
James said he was interested.
So that leaves 3 sets left unspoken for. $75.00 shipped
I don't get these made that often so get them while you can.
Old Aug 28, 2005 | 11:47 PM
  #190
mrkanda's Avatar
I'm interested, but need to come up with the dough. I actually started messing with my rear drums to have a look inside and the rear passenger side bound up and wouldn't come off. I've since put it back together since I have to use the car for work. But I really want to fix the back brakes, hopefully doing the whole rear drums to disk thing asap. Keep me in mind for these brackets and I'll let you know when I can do it. Thanks.
-Mrkanda
Old Aug 29, 2005 | 08:16 PM
  #191
Dysfunctional
COUNT ME IN!!!!!
im SOO down for some really awsome rear breaks
Old Aug 29, 2005 | 09:28 PM
  #192
CyMax's Avatar
Ok I'm lazy and tired as heck, and all doped up on pain-killers. So A. This is still going on right? B. 75 shipped for what exactly?? C. It will fit under the stock 15's? D Was the ebrake issue (from page 1) solved?
Thank you for understanding how hard it is to keep ones eyes open and type in Vicoden land.
Oh Oh and one more thing. If I just have say... Brembro front blanks and upgraded pads, is this really worth it??
Old Aug 29, 2005 | 11:17 PM
  #193
Jeff92se's Avatar
I'm needing a caw
$75 shipped. "Jeff_Iwata@yahoo.com" is the paypal. Let me know who you are/what you are buying/shipping address.
Originally Posted by Dysfunctional
COUNT ME IN!!!!!
Old Aug 29, 2005 | 11:29 PM
  #194
Jeff92se's Avatar
I'm needing a caw
YES
2 BRACKETS
NO. BUT SOMEONE DID MENTION IT MIGHT FIT WITH SOME GRINDING
NO E-BRAKE ISSUE
All other questions aren't really related to this particular thread.
Old Aug 30, 2005 | 07:29 AM
  #195
mod or sell?
it DOES fit under the stock SE wheels with no grinding on the wheel.
I'm currently running it that way.
Old Aug 30, 2005 | 09:43 PM
  #196
CandiMan's Avatar
Say Candyman 5 times
it DOES fit under the stock SE wheels with no grinding on the wheel. I'm currently running it that way.
I had to grind my rear calipers in order for it to clear my 15" OEM wheels
Old Aug 31, 2005 | 06:24 AM
  #197
mod or sell?
mine cleared fine, very close, but fine.
maybe it was my rebuilt calipers that let it clear.
Old Sep 9, 2005 | 04:31 PM
  #198
Jeff92se's Avatar
I'm needing a caw
Sorry for the delay James. Sent today. BTW. I had a prepaid usps postmark that was in the car when it was stolen. If you get a box of poo poo, it wasn't from me. I'm hitting your trader rating now man.
I have 3 sets left.
Old Sep 12, 2005 | 11:02 PM
  #199
Dillbag's Avatar
Suprise butsechs!!!
did someone say something about grinding on the WHEELS for caliper clearance?
dude that is WAY not cool, very unsafe. Have you ever seen a wheel break while doing 70? Scariest Sheet Ever!
Oh, and btw, I have an '89 SE w/ rear disk, what do i need again? I'm interested.
Old Sep 13, 2005 | 12:29 AM
  #200
CandiMan's Avatar
Originally Posted by Dillbag
did someone say something about grinding on the WHEELS for caliper clearance? dude that is WAY not cool, very unsafe. Have you ever seen a wheel break while doing 70? Scariest Sheet Ever!
Since you have a earlier Max it will depend your production date. If your production date is before 10/1990 all you will need is a set of calipers, caliper mounting bracket and parking brake cable from a 1992-1994. If your production date is after 10/90 then all you will need is Jeff's bracket. Or one of these days I can show you everything in person since you're in the Charlotte area.
