Rubber thingy under the gas pedal...
there shouldn't be any reason to do this
have someone push the gas pedal (car off) all the way down while you look at the throttle body. It should open all the way. If not, adjust the throttle cable (in the FAQs).
if you remove that stopper, it'll just stretch out the cable
I don't think that will make you go any faster, but you could buy those wheels that I'm selling from the classifieds and that would get you some extra HP
Seriously though, it shouldn't do anything unless your throttle cable is not adjusted properly. Maybe I should double check mine to make sure it opens the TB all the way when floored, hmmm.
Originally Posted by MrGone
you mean there is a rubber peice that goes over that? hmmm
*adds one more thing to the 'need to get' list*
If I have a white metal thing showing "under" the gas pedal, am I missing something? I think I would be, but who knows.
Bah! I would take a picture, but you all would laugh at me
i do believe you're missing the black plastic piece that is found on there. i've taken it off before but there is no poin since the butterflies in the tb are opened all of the way (when the cable is adjusted properly).
At least there is on a carb.
sisi senor
if you cut a whole in the floor so that you could press it even futher
you might gain an extra 100hp
Originally Posted by silverlinekenne
I heard if you take it off you will gain a extra 50hp and just think
Yeah!!! I can't waitto try that... after I get that supercharger hood scoop offa ebay I should have like 10,000hp to the rear wheels from my twin turbo-twin supercharged 300zx motor!!
Ninety-two-se, maybe you can answer this for me, if I buy the supercharger hood scoop thing, would I have to point the front towards the passenger side of the car since the motor is sidways? I just don't know if it would work right if I put it on facing the front of the car.
Edit: Ok lock this thread up... we have the info we need... it has just gotten off topic and dumb
you know, i've actually looked into a blower setup on a vg before. i found a company who makes a intake manifold for a carb. throw on a nice carb and then toss on a blower. the blower scoop should be able to be pointed in any direction. i may actually look into trying this at some point. i have my maxima's vg that i can try it on but i'll need a car to do it with. i found a datsun 280z that i could swap my engine into so i might actually try it with that... that would be pretty sweet seeing a blower sticking out of the hood of either car (if the blower is actually functional)
ef9
Oct 4, 2015 08:43 AM
