Door hinges
Old Apr 20, 2004 | 05:30 PM
notos&w's Avatar
Door hinges
First, let me say hello. Now to my question:
The driver's side door hinges on my 90 max have about had it. the door no longer shuts properly. Instead it hits the latch and kind bangs its way shut.
What do you think? Should I try to adjust the striker and hinges or should I replace the hinges? Significant vertical play can be induced by applying pressure to the door edge.
Also, how difficult are the hinge bolts to access and what is a good source for the hinges?
Thx for any help you can offer.
Old Apr 20, 2004 | 05:48 PM
HTPerformance's Avatar
Check if they are universal(the same on all doors), if they are, then I have a set from the drivers-side rear door that could be used. $20 + Shipping send me a PM.
Brian
Old Apr 21, 2004 | 06:17 AM
eric93SE's Avatar
I have a little squeak thats developed on the drivers side door on my max. I gave it a shot of WD-40, but it still makes a grunt when braking hard.
I think Matt93se has replaced them before, or determined the problem. maybe he can shed some light.
Old Apr 21, 2004 | 08:11 AM
m_maxxy's Avatar
Take a look at <this>
Matt gave me some valuable tips on this issue.
Old Apr 21, 2004 | 04:52 PM
notos&w's Avatar
thanks for the info.
my problem is wear in the hinge, causing vertical play in the door. lube won't help.
does anyone know if the hinges are universal?
REDinLV
Aug 15, 2024 12:30 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
BobTX10
Oct 7, 2015 08:43 AM
