Window Auto Down Switch?
Old May 1, 2004 | 06:13 PM
Evil_Twin's Avatar
I'm not too sure what its called, but the oval thin switch, is it supposed to make my window go down all the way?.... Because it goes down with me tapping it like 3-4 times. Not sure if thats right, can anybody tell me if thats right or not, and if not how can I fix it?
Thanks in Advanced.
Old May 1, 2004 | 06:33 PM
ghostmax's Avatar
no, it's supposed to go down all the way when pressed once. i had that problem and tried to fix it by soldering. i ended buying a master switch from yard since the other buttons weren't working, and now it works fine. i also did the auto up mod, so it goes both ways
Old May 1, 2004 | 06:39 PM
DMad8724's Avatar
Yeah mine goes down in intervals of 1/3, so when I hit it once it goes down 1/3 of the way, twice 2/3s down, it worked a couple times when I first got it...I don't know why?
Old May 2, 2004 | 05:46 AM
usmanasif's Avatar
Yeah...resoldering will probably help both of you.
Old May 2, 2004 | 06:09 AM
DMad8724's Avatar
can you take a picture of what we're supposed to solder? I don't wanna do the wrong thing and open my doors when I wanna roll my windows down
Old May 2, 2004 | 06:19 AM
«§»Craig B«§»'s Avatar
actually, I dont think resoldering will help anything much here
these boards are a lot better made than the clocks and door lock timers and use surface mount components - which are a lot harder to solder. Also, they're a lot smaller parts - it uses a lot of 0805 chips (.08" by .05") so it's definitely not for someone who doesn't have training soldering things like that.
I fixed one switch for a friend by replacing one of the zener diodes (ZD2) on the board and a couple of the resistors around it. The problem is getting that part though - I was able to just pull it off another old board I had.
so basically I think you'll need a new switch
Old May 2, 2004 | 06:48 AM
DMad8724's Avatar
Craig do you have an idea about how much the switch would be from a pull it yourself junkyard, also could it be possible that that ones messed up too, I'd like to do that auto-up switch too, but seems pointless when I don't even have an auto-down.
Old May 2, 2004 | 06:56 AM
It really varies by yard, you'll have to go check it out or call them up. I'd say anywhere from $5-50.
And then you still have a used switch so I'd recommend getting it from the dealer.
You can easily try the auto-up thing. It'll take you about 30 minutes, if that. I'm not sure if it'll work or not though
Old May 2, 2004 | 07:33 PM
ghostmax's Avatar
fyi, i bought my master switch which was practically new for $20 from a yard. try to find one that has teh letters still on there. definitely do some bargaining too.
Old May 2, 2004 | 08:11 PM
95turbo gxe's Avatar
well Check this $hi7 out I can hit my auto down switch some times
and like stop it half way and my dam window wont roll back up for a
few minutes HELPPPPPP!!!!!!!!!!!
AaronL
Aug 8, 2020 10:31 AM
Fbana41
Aug 29, 2016 12:18 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Maximeltman
Sep 28, 2015 07:19 PM
