How much is it to replace my tranny fluid? its for a 5spd
Old May 3, 2004 | 11:05 PM
Cheocwa's Avatar
So how much is it? I know in some cars it is easy to do. But I ask some people and they say I need a lift. So how much do you guys usually pay? I need to switch to redline!
Old May 4, 2004 | 05:25 AM
Mizeree_X's Avatar
Getting back to his roots
Do it yourself. There is a sticky in the fluids and lubricants section about this. All you'll need is a socket set (with a 1/2" driver), and a $0.99 funnel with the long tube from autozone. It took me about an hour, but alot of the time was trying to get the filler cap off and the actual refill, as the viscosity of the fluid is pretty high.
Old May 5, 2004 | 10:20 PM
ghostmax's Avatar
I bought redline fluid mt-90 from www.myoilshop.com for about $7 per quart (need about 5 qts). They have pretty fast shipping too. Use the promo code 675421 for 10% off.
Old May 7, 2004 | 11:00 AM
Dysfunctional
yea, deffenatly get the Redline MT-90 tranny fluid ... it is really good. i noticed a big difference . its real easy to do as well. all u need is a 1/2 in wrench and the drain plug is unscrewed and you drain it, put the plug ( low tranny light indicator) and then you just fill err up with almost 5 bottles of the redline MT-90
and your all set. it helps alot in the summer, the heat wont effect it as much. well good luck.
-DYS
Old May 7, 2004 | 11:35 AM
MrGone's Avatar
I use Amsoil, If you go with Redline be absolutely sure it has a VLSD additive. A friend replaced his with it his LSD isnt working.
buy 5 quarts. It cost me about $50-60 after tax locally, and as these guys said, the part that takes the most time is filling/draining because of the viscosity.
Also make sure you loosen the filler cap before you loosen the drain. Mainly because if you drain it then find out you cant open the filler your SOL and also because it tends to make it drain faster.
Old May 20, 2004 | 10:53 AM
fugi43's Avatar
I will be getting all the fluid out of the tranny I'm buying. Either by forcing it out w/a flush or by letting it sit w/the drain open for a few days. So what it the total capacity of this thing? I know sometimes when you drain most of the fluid is still inside.
Also, where's a good place to pick up Amsoil? Can I use synthetic since the tranny has 78K mi on it?
Thanx
Old May 20, 2004 | 05:07 PM
Mizeree_X's Avatar
Thanx
Maybe you're thinking of an automatic tranny. When I drained my 5-speed transmission, almost all of the fluid came out. The fluid just sits in the housing, it doesn't go in any tubes or get pumped around. At worst, you can use ~1/2 qt of new stuff to "push" what little old stuff is still in there out. No need to wait for days to let it drain IMHO.
Old May 20, 2004 | 05:35 PM
MrGone's Avatar
IIRC you can do a flush by disconnecting the cooler lines and having the one coming from the tranny dump into a bucket and the one going to the tranny you pour the new fluid into. Stop once the color of the fluid coming out is the same color as the new stuff (car has to be running though).
Old May 21, 2004 | 05:36 AM
internetautomar's Avatar
mod or sell?
2 words :
Kooler Douche (now called Kooler Klean, dam liberals)
rbuswell
Nov 17, 2016 04:54 AM
Ray229Harris
Sep 16, 2015 08:16 PM
Mrbizness1
Aug 18, 2015 08:43 PM
scarletsosa
Aug 17, 2015 09:09 PM
