anyone ever install a Warpspeed CAI?
Old May 7, 2004 | 02:36 PM
andy21's Avatar
it seems to me like the rubber 3" fittings that they send you don't fit somethings and they should be 3 1/2". Also it looks like it should have some type of bracket to keep it from shaking. I am also missing a few screws and the template to cut the fender. Has anyone every installed this so maybe you can help me solve these problems. I think i'm gonna have to call them up to talk about this
Old May 7, 2004 | 02:51 PM
KRMaxima21's Avatar
1> Try soaking the couplings in very hot water before you install them. It stretches them out a little. This way they'll fit and by the time you put them on they'll shrink right on to the pipes.
2>It wont shake once you finish putting everything in. I did mine and it took about 2 1/2 hours. The hole for the intake was the scariest part (cutting it to my car was like me watching surgery on TLC. I was cringing like a lil b**ch!)
3> When you put the pipe in you'll see exactly where to cut the hole at. It has to be at least about 3 1/2 in. in diameter
Old May 7, 2004 | 03:38 PM
Pit5Bull's Avatar
@andy21,
Check out my website, bro. I have some photos of the Bomz CAI I just installed into my car, and I used the template to cut the hole that was mentioned in an earlier thread in the 3rd Gen Forum (you'll have to look back to find it). Because the CAI I purchased and installed was designed for a 90-93 Honda Accord, I had to make a couple of modifications to it in order to get it to fit. One thing that I had to do on mine was to cut the coupling I used connecting the MAF adapter to the end pipe leading into the wheel well because one end was larger than the other Don't know who the brainchild that designed this was because all the piping is 3" in diameter. Why anyone would ship it with a coupling that's got one end too small to connect a 3" diameter MAF adapter/MAF is beyond me...
I had to split the work into two different phases in order to get it done, (connected the "S"-shaped pipe from the TB to the MAF first, and used my old cone filter until I could work on it again. - "ram-intake" setup. The following weekend, I was able to set aside some time, figure out and make the proper modifications to the remaining CAI pieces, and finish the job). It's a wonderful mod - looks awesome and feels even better. I encourage anybody thinking about it to go for it. Changed the way I look at my car now! Since I don't have my y-pipe & cat installed yet, this is the best performance mod I've made to my car thus far. Once I get the y-pipe & hi-flow cat installed... it's a whole different ballgame, I'm afraid.
Good luck on your install, bro!
peace2u
Old May 7, 2004 | 04:46 PM
Seyath's Avatar
Is there any CAI for the VE that requires no cutting at all? Not really afraid to perform surgery to my Maxi, just don't have the time to cut. About for the VG? Any CAI that I can just get away with cutting?
Old May 7, 2004 | 05:02 PM
CamryKilla's Avatar
why dont you just go with a pop charger Seyath? I guess if you want a CAI bad enough......my guess would be that you have to cut a hole for any and every CAI, but I could be wrong
Old May 7, 2004 | 05:05 PM
Seyath's Avatar
MMMh, that's not a bad idea. I completely neglected that option. What is the difference in sound between the two. I don't want something extremely loud. Cops around the area aren't real happy with all the ricers around, I don't want to fall in that category...
Old May 7, 2004 | 05:35 PM
CamryKilla's Avatar
umm, I haven't heard any cars that just replaced the filter and not the pipe, but my friend just got a short ram intake and its pretty loud. If my friends CAMRY doesn't sound like rice, do you think the MAX will?
Old May 7, 2004 | 07:39 PM
Maxmus_X's Avatar
SHIFT_PANTS
I took out the oem filter and box and installed a cone filter in its place. I stll have the tube that goes from headlight to the box for a ghetto short ram deal. I also have a five speed and as long as I shift at about 2500 rpm it sounds like stock, after 3k the brrrroooom comes and you'll hear it. I also have the y-pipe from warp. I love the sound when I go to 3k and let go of the gas, sounds like I got turbo, but don't have the psssst at the end. Just bbbrrrrrrooooooom, nothing like it.
I'm thinking about gettin the cai from cosmo for like 110 shipped, I need the low end powa.
Old May 7, 2004 | 08:58 PM
Matt93SE's Avatar
STFU n00b!
If you don't want loud, then don't get a CAI. the CAI is VERY VERY loud. a WAI is better, but still pretty loud on the VE.
Old May 8, 2004 | 07:06 AM
djslinkyz's Avatar
i think jeff is working on a CAI that doesn't require cutting into the fender. i don't think it's quite finished yet though
Old May 8, 2004 | 09:25 AM
Jay93SE's Avatar
I left the tube from the headlight to the box in too. I put a cone filter on the MAF and took out the silencer on the mid pipe(hose?), and plugged the hole with a PVC pipe cap turned upside down from the hardware store. It works!
Old May 8, 2004 | 11:40 AM
Cliff Clavin's Avatar
Way out West
I have the same kind of "ghetto short ram" deal like Maxmus was talking about. Just like his, it is not loud until you get to the higher RPM range.
here's a pic:
Old May 8, 2004 | 03:57 PM
HTPerformance's Avatar
if all you are looking for is a better growl and dont want to spend the dough on the CAI, just remove the resonator and plug up the hole in the intake.
Brian
Excalibur23
Oct 13, 2015 04:33 PM
lrb6805
Sep 17, 2015 04:49 PM
2kmaximel
Sep 16, 2015 03:19 PM
A32goldylocks
Sep 16, 2015 01:33 PM
Samedi
Sep 3, 2015 01:07 PM
