Speaker problem
Old May 26, 2004 | 03:57 AM
Keeler's Avatar
Speaker problem
OKay I'm new to the site but I"ve looked and looked but I haven't found anything that has helped me. I bought some aftermarket 6 by 9's for my 89 max se, It still ahs the original bose system but the rear speakers were blown so I opted to replace them. I got the speakers mounted but when I tried to connect them all I get is a scratchy noise, no real sound. The old Bose speakers still get regular sound but it's crappy since ones blown and the other is dying. Anyone know what I can do to fix this? I also plan on adding a cd player to the dash instead of the old am/fm tape.
Old May 26, 2004 | 04:41 AM
Jay93SE's Avatar
Check the FAQ's and Stickie's in the audio forum. The Bose system has integral amps mounted to each speaker, that's problem #1. Problem #2 is that the Bose operates with a screwy 1ohm setup.
Your going to have to get an aftermarkey Hu and an adapter to convert the signal to your front's from 4-8ohm to 1 ohm. the best solution would be to replace evrything with an aftermarket system. you will also need an adapter to convert the Nissan Diversity antenna to a standard plug. Cheers!
Old May 26, 2004 | 05:18 AM
Cliff Clavin's Avatar
Way out West
If you use aftermarket speakers and an aftermarket HU, your best bet is to bypass the amps.
Once you move away from Bose, you have to basically do the whole car. Some things may work in the short term, but eventually all of your amps and/or speakers will go and it's easier just to do the whole thing aftermarket.
just my $.02
Old May 26, 2004 | 05:26 AM
Keeler's Avatar
Thanks for the help but how much will all of this cost me, an estimate cause Ionly have about 200 left to spend on the sound, I already got the cd player though...
Old May 26, 2004 | 05:42 AM
Jay93SE's Avatar
You should be able to spend less than $200 on decent fronts for your max. You already have an HU and rears. Get an adapter harness($10), an antenna adapter($5-$10), and some speaker wire($5-$10). You might be better off running new wire from the HU to the speakers. Basically, you still have $170 for speakers!
Old May 26, 2004 | 07:06 AM
StRacer718's Avatar
To escape that problem I just had the entire system rewired when I changed the speakers and HU. I kept hearing other components don't work off the Bose setup.
Old May 26, 2004 | 07:19 PM
AscendantMax's Avatar
spend that left-over money on some nice front speakers. the front speakers are more important than the rears. the rears are mainly just for fill.
Old May 27, 2004 | 07:34 AM
Scope's Avatar
Im izz sexay
Get some ebay 6x9's in the rear and some CDT Components in the front ohh yeah
Old May 27, 2004 | 08:33 AM
TooEasy's Avatar
what he said. cept replace cdt with alpine type x and youll be in heaven
Old May 27, 2004 | 08:39 AM
floods943's Avatar
Haha, I got fed up with trying to rewire my rear 6x9s (i had the bose system...) So I installed everything, routed most of the wiring, left my dash and everything undone and then took it to my aunts friend who wired it correctly for $30.
Good stuff
Mar 12, 2020 12:06 AM
Excalibur23
Oct 13, 2015 04:33 PM
popdedop
Sep 11, 2015 11:17 AM
videomano
Sep 8, 2015 03:28 PM
