91 Maxima Strange Front End Noise
Old May 27, 2004 | 09:31 AM
gordo30's Avatar
My maxima drives fine until I get up to about 70-75 mph and a loud rattling/vibration noise comes from the passenger side (sounds like it is coming from the front wheel area). There is no vibration of the car - just this wierd noise and as soon as I slow down a little bit it stops. Sometimes it happens around 65 mph, other times not until 80 mph and sometimes it doesn't happen for a few days - regardless of how fast I am driving. Can someone please help me with this? Thanks a lot.
Old May 27, 2004 | 10:23 AM
gordo30's Avatar
Wheel Bearing?
Is it maybe a wheel bearing? Someone please answer because I have been going through the postings here b/c the search function is messed up. I need to get some input so I can get an idea of how much it will cost me.
Old May 27, 2004 | 11:03 AM
TooEasy's Avatar
heh, this maybe totally off base, but if your nose bra isnt correctly anchored it will flap pretty loudly at high speeds, however i wouldnt reccomend driving at speeds of 80+ until you figure out the root of the problem, that certainly isnt safe.
Old May 27, 2004 | 11:39 AM
Cheocwa's Avatar
mostlikely its your wheel bearing(s) does it get any louder when you turn one way or the other? I had my wheel bearings replaced recently because mine would start vibrating at 40!
Old May 27, 2004 | 11:43 AM
gordo30's Avatar
Nose bra?
I don't have a bra on my car. I was just thinking, though, that there is some kind of plastic insert in the wheel well directly in front of the tire. There is a screw (or two) missing from it and the air resistance is causing it to rub against the tire?
It mainly happens on a particular stretch of road on my way home from work where there is always a head wind. I am going to put replace the missing screws and we'll see what happens on the drive home today. I will post the results this evening.
Old May 27, 2004 | 11:47 AM
gordo30's Avatar
It gets a little louder the faster I go - but does not get any louder if I change lanes or am turning at all.
maxinout93
Oct 27, 2015 01:29 PM
kingw323
20
Oct 21, 2015 08:36 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
kirkhilles
Aug 8, 2015 10:53 AM
laparka66
Aug 6, 2015 09:36 AM
